What is the Settings For Sub Menu Items to show on top of page content not behind or under?
David Marchione
David Marchione posted this 17 May 2016
My sub menu items are showing behind/under the page content. Which setting brings the pull-down menu items in front of page content?
10 Comments
David Marchione
If it scrolls the menu item is not hidden. See www.webnetmarketingstudio.com the sub menu item under Web Design.
David Marchione
David Marchione posted this 18 May 2016
I found the solution setting the Z-Index to 100.
David Marchione
I thought I had it but when I scrolled over the menu item only half the first menu item hidden behind the slider image, the change to z-index 100 helped only when when clicking the top menu item bringing the sub menus forward. So I played with the slider setting the z-index to 0. This seemed to work unless I find another problem I may have caused.
Support Team posted this 19 May 2016
Nice to hear that it works for you now. In case the issue happens again please provide an access to your site back end and the marked screen shot demonstrating the issue.
Hi, Nice to hear that it works for you now. In case the issue happens again please provide an access to your site back end and the marked screen shot demonstrating the issue. Sincerely, Hella
chris.white
chris.white posted this 06 January 2018
I have this same problem. My horizontal menu drops down behind the sidebar that is below it. How do I get it to show on top of the sidebar?
Support Team posted this 09 January 2018
Have you tried to set the position to relative and z-index to 1000 for your Header control? If that does not help, create a private topic and provide an access to the site back end so we could review the settings.
Hi, Have you tried to set the position to `relative` and z-index to `1000` for your Header control? If that does not help, create a private topic and provide an access to the site back end so we could review the settings. Sincerely, Hella
chris.white
chris.white posted this 09 January 2018
Thank you, it was the requirement to set the position to Relative that solved the problem. I should have looked at the CSS manual first. Setting to 5 z-index was enough to bring it to the front.
Support Team posted this 10 January 2018
You are welcome. I usually suggest to set it to 1000 in case some other elements do have another z-index values that may be high.
Hi, You are welcome. I usually suggest to set it to 1000 in case some other elements do have another z-index values that may be high. Sincerely, Hella
sakthi
sakthi posted this 30 April 2018
Hi, I also faced the problem in Mobile Menu, why the dropdown in mobile menu showing half of the menu only? Please refer attachment.
Support Team posted this 02 May 2018
The problem may be in the menu width. Try to set it to 100%. If that does not help, create a private topic with the access to the site back end so we could review the settings.
Hi, The problem may be in the menu width. Try to set it to 100%. If that does not help, create a private topic with the access to the site back end so we could review the settings. Sincerely, Hella
