Can i save content i built inside themeler and import it?
shaulhadar
shaulhadar posted this 16 June 2014
Hi, in artisteer there was an option to build all the pages with content, and after export to add those pages to the site including content, is there a way to do it with themler?
Also, is there anyway to work on the site through themeler, and add plugins and stuff and than export it and import everything you worked on?
Thanks....
Hi, in artisteer there was an option to build all the pages with content, and after export to add those pages to the site including content, is there a way to do it with themler? Also, is there anyway to work on the site through themeler, and add plugins and stuff and than export it and import everything you worked on? Thanks....
Support Team posted this 16 June 2014
We decided to not include such option in Themler.
We made ​​this decision because CMS separates the content and the design and controls the content only. The CMS doing it great. And we believe that it's better for Themler to focus on the design only. So the Themler does not control CMS content in any way.
But Themler allows you to see the real website content. This will help you to see how the website will look in the final during designing process.
In addition to this in Themler you can add static content (using HTML, Text, TextGroup controls) which will appear on the specific page template. This will be a "content" of the page template. But this "content" will be a part of the design.
If you want some "content" to appear on the multiple page templates you can copy the control and Paste it or Paste as Link to the chosen page template(s).
The Paste option will create a separate copy of the control. The Past as link will add the same control. So the changes made to this control on one of the page templates will be applied to the rest controls on the other page templates.
Thank you.
Hello, We decided to not include such option in Themler. We made ​​this decision because CMS separates the content and the design and controls the content only. The CMS doing it great. And we believe that it's better for Themler to focus on the design only. So the Themler does not control CMS content in any way. But Themler allows you to see the real website content. This will help you to see how the website will look in the final during designing process. In addition to this in Themler you can add static content (using HTML, Text, TextGroup controls) which will appear on the specific page template. This will be a "content" of the page template. But this "content" will be a part of the design. If you want some "content" to appear on the multiple page templates you can copy the control and Paste it or Paste as Link to the chosen page template(s). The Paste option will create a separate copy of the control. The Past as link will add the same control. So the changes made to this control on one of the page templates will be applied to the rest controls on the other page templates. Thank you.
shaulhadar
shaulhadar posted this 18 June 2014
Thanks for the clarification, I understand..
Have a great day :)
Thanks for the clarification, I understand.. Have a great day :)
Support Team posted this 18 June 2014
You're welcome!
You're welcome!
Adjuvatio
Adjuvatio posted this 17 April 2016
Hallo, what a Bullshit?
Why should i Use Themler without these funktion? thats stupid and that make no sense
Hallo, what a Bullshit? Why should i Use Themler without these funktion? thats stupid and that make no sense
The topic is quite old and now you have ability to edit the content for wP and Joomla and also export content for the HTML templates.
So you need to install the theme in the live site and there you will be able to edit the content of the site.
Hi, The topic is quite old and now you have ability to edit the content for wP and Joomla and also export content for the HTML templates. So you need to install the theme in the live site and there you will be able to edit the content of the site. Sincerely, Hella
