Horizontal menu submenus not appearing behind section
andrew34
andrew34 posted this 25 May 2016
Here's the site:
http://rapidregisteredagent.com
The sub-menu items of the horizontal menu to the right of the logo do not appear above the picture below them until I scroll down a little.
Here's the site: http://rapidregisteredagent.com The sub-menu items of the horizontal menu to the right of the logo do not appear above the picture below them **until** I scroll down a little.
9 Comments
andrew34
Also, on this page:
http://rapidregisteredagent.com/about-us/
It's not possible to select the third submenu under "About Us"
Also, on this page: http://rapidregisteredagent.com/about-us/ It's not possible to select the third submenu under "About Us"
amplid
amplid posted this 25 May 2016
Same Problem here.....
http://mmblog.maic-web.ch/
Submenu Position is "relative" and z-index is 100 (just to be safe i tried 100000)
Submenu Position is "relative" and z-index is more than 1
Same Problem here..... http://mmblog.maic-web.ch/ Submenu Position is "relative" and z-index is 100 (just to be safe i tried 100000) ![Submenu Position is "relative" and z-index is more than 1][1] [1]: http://i.imgur.com/iSUwuOq.png
Stagger Lee posted this 26 May 2016
Seems as those Sections are making something. Bring some strange CSS lines.
I checked on my 3 themes and dont have this problem, no sections there.
Seems as those Sections are making something. Bring some strange CSS lines. I checked on my 3 themes and dont have this problem, no sections there.
Support Team posted this 26 May 2016
Please try to set position relative and z-index about 1000 for the section that includes menu. If that does not help, provide an access to your site back end.
Hi, Please try to set position relative and z-index about 1000 for the section that includes menu. If that does not help, provide an access to your site back end. Sincerely, Hella
amplid
amplid posted this 26 May 2016
Well....thats the solution...thx to the support! already an z-index of 1 was enougth.....
enter image description here
> Hi, > > Please try to set position relative and z-index about 1000 for the section that includes menu. If that does not help, provide an access to your site back end. > > Sincerely, > Hella Well....thats the solution...thx to the support! already an z-index of 1 was enougth..... ![enter image description here][1] [1]: http://s33.postimg.org/e5u0g4ynj/Fixed.png
vitalii.reznic
vitalii.reznic posted this 27 February 2018
Hello. The same problem. I tried to change the Z-index for menu section and for the slidebar section. It didn`t help.
How can I privide an acces to my site back end?
> Hi, > > Please try to set position relative and z-index about 1000 for the section that includes menu. If that does not help, provide an access to your site back end. > > Sincerely, > Hella Hello. The same problem. I tried to change the Z-index for menu section and for the slidebar section. It didn`t help. How can I privide an acces to my site back end?
Support Team posted this 27 February 2018
Hi Vitalii,
Please feel free to create a new private topic and describe your issue there.
It's also safe to post your back-end credentials there.
Ivan
Hi Vitalii, Please feel free to create a new private topic and describe your issue there. It's also safe to post your back-end credentials there. Thanks, Ivan
aureliop
aureliop posted this 12 January 2019
I've the same problem:
http://cll.ypunto.mx
If you select the fifth element in the horizontal menu (Noticias y recursos) you can see the submenu elements.
But if you select one of them, the second is behind and cannot be seen.
What can I do?
Aurelio
Hi, I've the same problem: http://cll.ypunto.mx If you select the fifth element in the horizontal menu (Noticias y recursos) you can see the submenu elements. But if you select one of them, the second is behind and cannot be seen. What can I do? Thanks Aurelio
