Woocommerce shipping calculator
mrvargo
mrvargo posted this 30 May 2016
Just a small issue but in Woocommerce cart I have two shipping calculators more or less alongside each other. If I disable the calculator they both disappear. Is it possible to just show one, preferably the one on the right?
21 Comments
Support Team posted this 30 May 2016
Can you provide a link to the site to see the issue?
Also dos it happen with the non-Themler theme?
Hi, Can you provide a link to the site to see the issue? Also dos it happen with the non-Themler theme? Sincerely, Hella
mrvargo
http://dementiashop.com.au/cart/
Doesn't happen in the old Artisteer theme
http://dementiashop.com.au/cart/ Doesn't happen in the old Artisteer theme
Support Team posted this 31 May 2016
I could not reproduce the issue with the default Themler theme for wooCommerce: a calculator on the left appears but not under Cart Totals.
Please try to temporarily disable all CMS plugins and also clear CMS caches.
Let us know if the issue persists.
Hello, I could not reproduce the issue with the default Themler theme for wooCommerce: a calculator on the left appears but not under Cart Totals. Please try to temporarily disable all CMS plugins and also clear CMS caches. Let us know if the issue persists. Sincerely, Nettie, BillionDigital Team
Linkebel
Linkebel posted this 31 May 2016
I see also 2 blocks delivery
I also have this on my website WooCommerce I did disappear with a display none but how in Themler?
I see also 2 blocks delivery I also have this on my website WooCommerce I did disappear with a display none but how in Themler?
mrvargo
mrvargo posted this 31 May 2016
Good idea. Can be hidden with the following css:
#shipping-calculator {display: none;}
Good idea. Can be hidden with the following css: `#shipping-calculator {display: none;}`
Support Team posted this 01 June 2016
Linkebel,
mrvargo,
This is weird: looks like there is some specific setting on your websites enabled that is not default, or some plugin.
Maybe you could create private topic and provide temporary access to your website for investigation?
**Linkebel**, **mrvargo**, This is weird: looks like there is some specific setting on your websites enabled that is not default, or some plugin. Maybe you could create private topic and provide temporary access to your website for investigation? Sincerely, Nettie, BillionDigital Team
rogier
rogier posted this 26 July 2016
Any solution known yet?
I am suffering the same problem...
Kind regards, Rogier
Hi, Any solution known yet? I am suffering the same problem... Kind regards, Rogier
Support Team posted this 26 July 2016
Rogier,
We still could not reproduce the issue. Could you please create a prviate topic and provide temporary access to your website so that we could investigate the issue?
**Rogier**, We still could not reproduce the issue. Could you please create a prviate topic and provide temporary access to your website so that we could investigate the issue? Sincerely, Nettie, BillionDigital Team
picturesque
picturesque posted this 15 August 2016
What was the solution? I'm having the same issue.
Support Team posted this 16 August 2016
You are talking about the duplicating checkout button? Please provide a link to the site where we could see the issue.
Hi, You are talking about the duplicating checkout button? Please provide a link to the site where we could see the issue. Sincerely, Hella
oceanite
oceanite posted this 07 December 2016
I have the same problem. How to solve the problem, please ?
Hello, I have the same problem. How to solve the problem, please ? Thanks Regards
tech51
tech51 posted this 07 December 2016
I have not heard any solution to this problem and it's been a couple of months I'm assuming there's no fix in there will be no update
oceanite
Ok, thanks
> I have not heard any solution to this problem and it's been a couple of months I'm assuming there's no fix in there will be no update Ok, thanks
oceanite
works for me, thanks mrvargo
regards
> http://dementiashop.com.au/cart/ > Doesn't happen in the old Artisteer theme works for me, thanks mrvargo regards
Support Team posted this 08 December 2016
Unfortunately the fix for this issue wasn't included into the most recent update as hotfix.
The fix will be available in the next update.
Themer Team
Hi, Unfortunately the fix for this issue wasn't included into the most recent update as hotfix. The fix will be available in the next update. Thank you, Themer Team
tech51
tech51 posted this 08 December 2016
I am sorry I am not trying to cause any problems but the same message you had sent it to me in a private when is the next available in 6 month... what do I tell my customer that he needs to wait 6 months for this to get fix the first thing he's going to say is what kind of service I'm providing to him. I think that if there's a problem with the software you should be taking care immediately not to wait 6 months 4 months to get it fix when my subscription stops I need to pay right away because you will cut the service and you will not wait for months for me to pay
Support Team posted this 12 December 2016
Hello Roberto,
please refer to my response for relevant topic http://answers.themler.com/questions/105998/two-shipping-calculators
Hello Roberto, please refer to my response for relevant topic http://answers.themler.com/questions/105998/two-shipping-calculators regards, Aileen
len
len posted this 04 March 2017
I also have this issue with Themler v.355, so the issue is not fixed. Can you please confirm when the fix will be available.
This happens in the main browsers on Windows10: Edge and Chrome, not tested on a Mac.
Its not just the double display, the calculator does not function.
I cannot select the country in the calculator, so the calculator does not work.
I tried typing in a county outside the UK (california) but nothing happens (see screen shot)
In Themler Desktop, I can't see or find any reference to calculator fields, and they don't appear a any configurable areas in the Cart control.
Aileen: the refernce below no longer exists:
LenW
I also have this issue with Themler v.355, so the issue is not fixed. Can you please confirm when the fix will be available. This happens in the main browsers on Windows10: Edge and Chrome, not tested on a Mac. Its not just the double display, the calculator does not function. I cannot select the country in the calculator, so the calculator does not work. I tried typing in a county outside the UK (california) but nothing happens (see screen shot) In Themler Desktop, I can't see or find any reference to calculator fields, and they don't appear a any configurable areas in the Cart control. Aileen: the refernce below no longer exists: please refer to my response for relevant topic http://answers.themler.com/questions/105998/two-shipping-calculators LenW
tech51
tech51 posted this 04 March 2017
Mr.len they have promised me so many times that they are going to fix the problem within the next update and then never do I had the same problem since last year I hope everybody gets together and not renew the contract that way they will be forced to fix the problem
tech51
I started complaining out last year and they still have not fix the problem look at my link
I started complaining out last year and they still have not fix the problem look at my link http://answers.themler.com/questions/105998/two-shipping-calculators
