Internal link
p-roehl
p-roehl posted this 06 June 2016
I can not find a way to put a link from a photo in a site to an other internal site. The same is if I try to set an internal link from a text to an existing internal site.
So it seems to be impossible to create links to other subsides out of a text or a picture.
Hello, I can not find a way to put a link from a photo in a site to an other internal site. The same is if I try to set an internal link from a text to an existing internal site. So it seems to be impossible to create links to other subsides out of a text or a picture.
Support Team posted this 07 June 2016
Try add image control (Insert -> Image) and configure
Themler team
Hi, Try add image control (Insert -> Image) and configure !internal-link.png! Regards, Themler team
p-roehl
p-roehl posted this 14 September 2016
The internal links can still not placed in a comfortable way (good example is mobi rise). The solution you suggested is not working right and they is not to compare with the artisteer way. Why do you not improve this feature? The rest of the themler is very good!
Best regards
The internal links can still not placed in a comfortable way (good example is mobi rise). The solution you suggested is not working right and they is not to compare with the artisteer way. Why do you not improve this feature? The rest of the themler is very good! Best regards
Support Team posted this 15 September 2016
As I understand, you are referring to an option to set a link for an image that is present also in Themler: select the image and fill in the address in the Image tab > Link:
Hello, As I understand, you are referring to an option to set a link for an image that is present also in Themler: select the image and fill in the address in the Image tab > Link: !i367.png! Sincerely, Nettie, BillionDigital Team
p-roehl
p-roehl posted this 25 December 2017
You probably can not understand the problem. I would like to link to an internal page. In addition I would like to see a list with the sides from my web page in which I can select. Good programs also offer the possibility to link to an anchor. That all was possible in Artisteer. You only offers the possibility to enter complete links including http.
Support Team posted this 25 December 2017
You can also set link as #test. It works ok too.
Hi, You can also set link as `#test`. It works ok too. Thank you, Olivia
