The Events Calendar plugin does not display properly.
alleminbe
alleminbe posted this 06 June 2016
I am using the events calendar plugin, but when I clicked on a particular event, the page generated by the plugin completely overrides the themler theme.
Is there a fix for that?
Site: http://www.leedscityescort.com/
Events: http://www.leedscityescort.com/event/event-2/2016-06-03/
I am using the events calendar plugin, but when I clicked on a particular event, the page generated by the plugin completely overrides the themler theme. Is there a fix for that? Site: http://www.leedscityescort.com/ Events: http://www.leedscityescort.com/event/event-2/2016-06-03/ Regards
27 Comments
Support Team posted this 07 June 2016
I suppose that the mention calendar page uses Themler Default template.
Thus, please make sure that you've set to output Header and Sidebars for this template in Themler.
Please provide us with a temp access to your WP back-end if you need any further assistance.
Ivan
Hi, I suppose that the mention calendar page uses Themler Default template. Thus, please make sure that you've set to output Header and Sidebars for this template in Themler. Please provide us with a temp access to your WP back-end if you need any further assistance. Thanks, Ivan
alleminbe
alleminbe posted this 07 June 2016
How would I set the output Header and Sidebars for this template in Themler correctly.
Could you please provide us with a temp access to your theme so we can try to help you.
Ivan
Hi, Could you please provide us with a temp access to your theme so we can try to help you. Thanks, Ivan
alleminbe
Will you show me what is the fix? I didn't finish with the theme yet, will I be able to edit it as usual on Themler after the fix.
Will you show me what is the fix? I didn't finish with the theme yet, will I be able to edit it as usual on Themler after the fix. Regards,
alleminbe
alleminbe posted this 09 June 2016
Is their any improvements?
Support Team posted this 10 June 2016
when I access the
http://www.leedscityescort.com/wp-admin/ and log in I get the following message
You do not have sufficient permissions to access this page.
Please check the user credentials under which we log in
Hello, when I access the http://www.leedscityescort.com/wp-admin/ and log in I get the following message You do not have sufficient permissions to access this page. Please check the user credentials under which we log in regards, Aileen
alleminbe
alleminbe posted this 10 June 2016
Here are the information needed:
Site: http://toni.leedscityescort.com/
Calendar: http://toni.leedscityescort.com/calendar/
Event: http://toni.leedscityescort.com/event/event-2/2016-06-03/
Regards.
Hi Here are the information needed: Site: http://toni.leedscityescort.com/ Calendar: http://toni.leedscityescort.com/calendar/ Event: http://toni.leedscityescort.com/event/event-2/2016-06-03/ Regards.
Support Team posted this 14 June 2016
Our developers have found a workaround for Event Calendar.
Please try to add the following piece of code to Themler Settings - CMS Code:
function _tribe_events_after_the_grid() {
    echo '%%theme_more%%';
    add_filter('pre_option_theme_show_morelink', create_function('', 'return 0;'));
add_action('tribe_events_after_the_grid', '_tribe_events_after_the_grid');
This should help.
Let us know the results.
Hello, Our developers have found a workaround for Event Calendar. Please try to add the following piece of code to Themler Settings - CMS Code: function _tribe_events_after_the_grid() { echo '%%theme_more%%'; add_filter('pre_option_theme_show_morelink', create_function('', 'return 0;')); } add_action('tribe_events_after_the_grid', '_tribe_events_after_the_grid'); This should help. Let us know the results. regards, Aileen
alleminbe
alleminbe posted this 15 June 2016
I have added the code in the CMS code, it didn't work, the event page still shows the same still overrides the themler theme..
I even deactivate and activate the plugin.
enter image description here
I have added the code in the CMS code, it didn't work, the event page still shows the same still overrides the themler theme.. I even deactivate and activate the plugin. http://toni.leedscityescort.com/event/event-2/2016-06-03/ ![enter image description here][1] [1]: http://attachments.answers.billiondigital.com/49/16049/event.jpg
alleminbe
alleminbe posted this 17 June 2016
Is there a repair or a fix please.
I am too delayed for this project.
Is there a repair or a fix please. I am too delayed for this project.
Support Team posted this 17 June 2016
Could you point out what exactly is lost in style now?
This is the screenshot of event
Hello, Could you point out what exactly is lost in style now? This is the screenshot of event !EventStyle.png! regards, Aileen
alleminbe
What is the URL of this screenshot?
The site is http://toni.leedscityescort.com/ not http://leedscityescort.com/
The CMS code you provided never worked.
Please insert the code in the CMS area in Themler.
I hired the plugin developers to modify the plugin to work on Themler theme http://leedscityescort.com/, I want to know how to modify the themes created in Themler for the plugin to work as I don't want to hire their developers each time I would like to use the plugin.
Regards.
What is the URL of this screenshot? The site is http://toni.leedscityescort.com/ not http://leedscityescort.com/ http://toni.leedscityescort.com/event/event-2/2016-06-03/ The CMS code you provided never worked. Site: http://toni.leedscityescort.com/ Calendar: http://toni.leedscityescort.com/calendar/ Event: http://toni.leedscityescort.com/event/event-2/2016-06-03/ Please insert the code in the CMS area in Themler. I hired the plugin developers to modify the plugin to work on Themler theme http://leedscityescort.com/, I want to know how to modify the themes created in Themler for the plugin to work as I don't want to hire their developers each time I would like to use the plugin. Regards.
I'm sorry for the inconvenience.
I see the issue now. I'm passing it to developers for review and we'll contact you when solution or workaround is available
Hello, I'm sorry for the inconvenience. I see the issue now. I'm passing it to developers for review and we'll contact you when solution or workaround is available regards, Aileen
alleminbe
alleminbe posted this 24 June 2016
How long do you think I will get a respond from the developer team?
Support Team posted this 27 June 2016
I'm sorry for delay in response.
The issue is rather related to The Events Calendar plugin, not Themler. The page which outputs certain event (http://toni.leedscityescort.com/event/event-2/2016-06-03/) is output by plugin, so it is displayed the page with its custom template. I.e. it replaces the Themlers template with its custom one to output this page.
We cannot do anything about it and recommend that you contact plugin developers, whether it is possible to output such pages with the same theme as used for the rest site pages
Hello, I'm sorry for delay in response. The issue is rather related to The Events Calendar plugin, not Themler. The page which outputs certain event (http://toni.leedscityescort.com/event/event-2/2016-06-03/) is output by plugin, so it is displayed the page with its custom template. I.e. it replaces the Themlers template with its custom one to output this page. We cannot do anything about it and recommend that you contact plugin developers, whether it is possible to output such pages with the same theme as used for the rest site pages regards, Aileen
alleminbe
alleminbe posted this 29 June 2016
Nothing is wrong with the plugin, the event pages shows in the theme of other wordpress themes, but not with Themler themes.
Support Team posted this 30 June 2016
Could you please check the Events Settings >> Display >> Basic Template Settings. If "Events template" is set to "Default Events template" please change it to "Default Page Template". In this case the events page may use theme styles partially.
Hi, Could you please check the Events Settings >> Display >> Basic Template Settings. If "Events template" is set to "Default Events template" please change it to "Default Page Template". In this case the events page may use theme styles partially. Thank you, Olivia
alleminbe
alleminbe posted this 01 July 2016
Where do I check the Events Settings?
I can't find it in thembler nor in the wordpress admin panel.
Please help.
Where do I check the Events Settings? I can't find it in thembler nor in the wordpress admin panel. Please help.
Support Team posted this 04 July 2016
I installed this plug-in on my local WordPress. Now I have the menu on my WP Sidebar with item "Settings":
Hi, I installed [this plug-in][1] on my local WordPress. Now I have the menu on my WP Sidebar with item "Settings": !events-plugin.png! Thank you, Olivia [1]: https://wordpress.org/plugins/the-events-calendar/
alleminbe
alleminbe posted this 04 July 2016
This is the wrong plugin https://wordpress.org/plugins/the-events-calendar/ we are trying to solve The Events Calendar.
The plugin I am using is https://wordpress.org/plugins/event-calendar-wd/ Calendar.
No wonder I couldn't find the settings under events at the first place.
This is the wrong plugin https://wordpress.org/plugins/the-events-calendar/ we are trying to solve The Events Calendar. The plugin I am using is https://wordpress.org/plugins/event-calendar-wd/ Calendar. No wonder I couldn't find the settings under events at the first place.
