Joomla module position in article ?
skygirl
skygirl posted this 06 June 2016
Are you possible to insert module joomla in article or it's a bug report ?
When I try sometimes it hangs and nothing appears (even watching locations) and other times it inserts an html site with ##position-8##
Please help me !
Thank you a lot
This code in html editor appear :
position-15
<div class>
</div> <div class>
</div> <div class>
</div> <div class>
</div> <h4>Title</h4>
    <div class="bd-blockcontent bd-tagstyles">
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nunc id dolor rutrum ipsum blandit vehicu</div>
Hello, Are you possible to insert module joomla in article or it's a bug report ? When I try sometimes it hangs and nothing appears (even watching locations) and other times it inserts an html site with ##position-8## Please help me ! Thank you a lot This code in html editor appear : ### position-15 ### &lt;div class&gt; &lt;/div&gt; &lt;div class&gt; &lt;/div&gt; &lt;div class&gt; &lt;/div&gt; &lt;div class&gt; &lt;/div&gt; &lt;h4&gt;Title&lt;/h4&gt; <div class="bd-blockcontent bd-tagstyles"> Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nunc id dolor rutrum ipsum blandit vehicu</div>
Support Team posted this 08 June 2016
Hello Sonia,
It is not possible to insert Joomla Position control inside Article or blog post.
How did you manage to insert Joomla Position control inside article?
Hello Sonia, It is not possible to insert Joomla Position control inside Article or blog post. How did you manage to insert Joomla Position control inside article? regards, Aileen
skygirl
skygirl posted this 28 June 2016
sorry for my late reply . This is to insert a contact form but I turned the other worries .
Thank you very much
Pleasure
Hello, sorry for my late reply . This is to insert a contact form but I turned the other worries . Thank you very much Pleasure
Support Team posted this 29 June 2016
Please let us know if you need our further help.
Hi, Please let us know if you need our further help. Sincerely, Hella
DaveOzric
DaveOzric posted this 12 May 2018
Is this something that can be changed to work someday or just not possible for some other reason? Editing an article in Themler I was hoping to add a module position. I can do a work around though.
Support Team posted this 14 May 2018
No, there is no such possibility technically and it won't be implemented in the future.
Hi, No, there is no such possibility technically and it won't be implemented in the future. Sincerely, Hella
DaveOzric
DaveOzric posted this 14 May 2018
That's fine, Joomla extensions typically have system plugins for this or a module load position may work.
Keep up the great work! Themler is the bomb!
That's fine, Joomla extensions typically have system plugins for this or a module load position may work. Keep up the great work! Themler is the bomb!
Thanks for your feedback. Feel free to contact us again.
Thanks for your feedback. Feel free to contact us again. Sincerely, Hella
