Can´t change style on product buy button within a new row
PK Webdesign
PK Webdesign posted this 06 June 2016
Hi!
I inserted a "section" in to a column in my product details and made 3 columns within that. I want the "quantity" and "add to cart" button in the same line. Now I can´t change the style, they are only blue and I want i purple like you see in the image.
And how should I make a hr line in between the price and the 3 new columns?
Can I also delete the +- in the quantity, want the customer to write it in?
Availability, can´t find the control for that, is there any?
Noticed now when I tried, can´t add the control "Product out of stock", want that in the product details.
/Peter
Hi! I inserted a "section" in to a column in my product details and made 3 columns within that. I want the "quantity" and "add to cart" button in the same line. Now I can´t change the style, they are only blue and I want i purple like you see in the image. And how should I make a hr line in between the price and the 3 new columns? Can I also delete the +- in the quantity, want the customer to write it in? Availability, can´t find the control for that, is there any? Noticed now when I tried, can´t add the control "Product out of stock", want that in the product details. /Peter
PK Webdesign
I found the solution of the style issue. I added a "Layout Container" instead of the "Section".
I still have the other issues.
I found the solution of the style issue. I added a "Layout Container" instead of the "Section". I still have the other issues.
Support Team posted this 08 June 2016
For add hr line you can use 'Separator' control. You can find it on Insert Ribbon tab.
'+', '-' buttons and availability is a CMS output. So add or remove it you can by tune WooCommerce settings. For more details see https://docs.woothemes.com/documentation/plugins/woocommerce/getting-started/
To setup 'out of stock' control you need out of stock product to see control in themler. Set one of product as out of stock in you WP admin. Then refresh content in themler and open this product page. You can add 'out of stock control' and setup it style.
Themler Team
Hi, For add hr line you can use 'Separator' control. You can find it on Insert Ribbon tab. '+', '-' buttons and availability is a CMS output. So add or remove it you can by tune WooCommerce settings. For more details see https://docs.woothemes.com/documentation/plugins/woocommerce/getting-started/ To setup 'out of stock' control you need out of stock product to see control in themler. Set one of product as out of stock in you WP admin. Then refresh content in themler and open this product page. You can add 'out of stock control' and setup it style. !refresh-content-button.jpg! Thank you, Themler Team
