The Events Calendar plugin does not display properly
alleminbe
alleminbe posted this 08 June 2016
I am using the events calendar plugin, but when I clicked on a particular event, the page generated by the plugin completely overrides the themler theme.
Is there a fix for that?
Site: http://www.leedscityescort.com/
Calendar: http://www.leedscityescort.com/calendar/
Events: http://www.leedscityescort.com/event/event-2/2016-06-03/
I am using the events calendar plugin, but when I clicked on a particular event, the page generated by the plugin completely overrides the themler theme. Is there a fix for that? Site: http://www.leedscityescort.com/ Calendar: http://www.leedscityescort.com/calendar/ Events: http://www.leedscityescort.com/event/event-2/2016-06-03/ Regards
Support Team posted this 14 June 2016
please refer to response for topic http://answers.themler.com/questions/83212/the-events-calendar-plugin-does-not-display-properly
Hello, please refer to response for topic http://answers.themler.com/questions/83212/the-events-calendar-plugin-does-not-display-properly regards, Aileen
Sem
Sem posted this 05 May 2017
I used the code and changed from the calendar settings to the page template and style start working, but there are still quite much issues. http://mhost.site/kmitchell/events/
1
when I use search filed to do each and click on find events button this code "%%theme_more%% " can be seen at the end of the calendar
2 view as week filter for example not working properly with the themler theme.
is there any solution?
Hi, I used the code and changed from the calendar settings to the page template and style start working, but there are still quite much issues. http://mhost.site/kmitchell/events/ 1 when I use search filed to do each and click on find events button this code "%%theme_more%% " can be seen at the end of the calendar 2 view as week filter for example not working properly with the themler theme. is there any solution? !fdfd.png!
Support Team posted this 16 May 2017
Hello Smbat ,
please submit new private topic where provide access to the WP admin back end and we'll check the issue.
Hello Smbat , please submit new private topic where provide access to the WP admin back end and we'll check the issue. regards, Aileen
