Menu item has submenu - Icon
Stagger Lee posted this 12 June 2016
Can you use pseudo-element ::after instead of ::before ?
There is not much logic to have icon before menu item on responsive menu, looks ugly.
But it is not main reason for asking. Position:absolute, or float:right on icon makes lot of problems in IE11 and below.
Just look how menu icons here look on Chrome and IE11:
http://templates.themler.com/Themes/Preview?id=2162320
Can you use pseudo-element ::after instead of ::before ? There is not much logic to have icon before menu item on responsive menu, looks ugly. But it is not main reason for asking. Position:absolute, or float:right on icon makes lot of problems in IE11 and below. Just look how menu icons here look on Chrome and IE11: http://templates.themler.com/Themes/Preview?id=2162320
Anyway, I decided to remove icon in IE11. Tweak after tweak and you ruin it for other more normal browsers.
@media screen and (-ms-high-contrast: active), (-ms-high-contrast: none) {
   /* IE10+ specific styles go here */
   .bd-menu-17.nav-pills .bd-menuitem-22 > a:before, .bd-menu-17.nav-pills .bd-menuitem-22 > a:link:before, .bd-menu-17.nav-pills .bd-menuitem-22 > a:visited:before {
    content: none !important;
Anyway, I decided to remove icon in IE11. Tweak after tweak and you ruin it for other more normal browsers. @media screen and (-ms-high-contrast: active), (-ms-high-contrast: none) { /* IE10+ specific styles go here */ .bd-menu-17.nav-pills .bd-menuitem-22 > a:before, .bd-menu-17.nav-pills .bd-menuitem-22 > a:link:before, .bd-menu-17.nav-pills .bd-menuitem-22 > a:visited:before { content: none !important; } }
Support Team posted this 16 June 2016
I've added your request to our wish list.
But this may help in case of specific icon alignment. This feature requires creating of different elements depending of the icon alignment and adding of the alignment option itself.
Hi, I've added your request to our wish list. But this may help in case of specific icon alignment. This feature requires creating of different elements depending of the icon alignment and adding of the alignment option itself. Thank you, Olivia
Stagger Lee posted this 16 June 2016
Can you explain it with other words ? I am not sure if I understand.
Support Team posted this 20 June 2016
I'm passing this issue to developers for closer analyses, we will let you know when we receive the results.
Themler Team
Hi, I'm passing this issue to developers for closer analyses, we will let you know when we receive the results. Thank you, Themler Team
Support Team posted this 28 June 2016
We receive a response from our developers. The issue happens because there is problem in IE. To fix the reported issue you can use a workarround. Add custom CSS code to your theme.
  1. Open Settings on Ribbon Home tab.
  2. Add Custrom CSS code
Code:
.bd-menu-1.nav-pills .bd-menuitem-2 > a > span {
 margin-right: 23px;
.bd-menu-1.nav-pills .bd-menuitem-2:last-child > a > span {
 margin-right: 0px;
.bd-menu-1.nav-pills .bd-menuitem-2 > a:before {
    margin-left: 0px !important;
This should help. Please keep us posted about the progress.
Themler Team
Hi, We receive a response from our developers. The issue happens because there is problem in IE. To fix the reported issue you can use a workarround. Add custom CSS code to your theme. 1. Open Settings on Ribbon Home tab. !settings-button-on-ribbon.jpg! 2. Add Custrom CSS code !additional-CSS.jpg! Code: .bd-menu-1.nav-pills .bd-menuitem-2 > a > span { margin-right: 23px; } .bd-menu-1.nav-pills .bd-menuitem-2:last-child > a > span { margin-right: 0px; } .bd-menu-1.nav-pills .bd-menuitem-2 > a:before { margin-left: 0px !important; } This should help. Please keep us posted about the progress. Thank you, Themler Team
Stagger Lee posted this 29 June 2016
If I hit it right it dramatically change menu item spacing in all browsers. It is used together with float:right, or not ?
Cannot get it to work.
If I hit it right it dramatically change menu item spacing in all browsers. It is used together with float:right, or not ? Cannot get it to work.
Support Team posted this 30 June 2016
Hello Stagger Lee,
to make the CSS be applied to IE only you may use media queries or conditional comments.
Refer to following articles for more details
http://webdesignerwall.com/tutorials/css-specific-for-internet-explorer
https://philipnewcomer.net/2014/04/target-internet-explorer-10-11-css/
Hello Stagger Lee, to make the CSS be applied to IE only you may use media queries or conditional comments. Refer to following articles for more details http://webdesignerwall.com/tutorials/css-specific-for-internet-explorer https://philipnewcomer.net/2014/04/target-internet-explorer-10-11-css/ regards, Aileen
