Woocommerce 2.6
Lenglemetz
Lenglemetz posted this 14 June 2016
Hi!
Themler 301 is not compatible with WooCommerce 2.6. The cart page no longer works.
Hi! Themler 301 is not compatible with WooCommerce 2.6. The cart page no longer works.
6 Comments
mrvargo
mrvargo posted this 15 June 2016
Same here. 'Update cart' and remove item ajax stuff no longer works.
MAKBIZ
MAKBIZ posted this 15 June 2016
I can confirm as well.
Another plugin I use for WooCommerce was updates weeks ago to work with 2.6.
Why is Themler so behind?
I can confirm as well. Another plugin I use for WooCommerce was updates weeks ago to work with 2.6. Why is Themler so behind?
Support Team posted this 16 June 2016
Hi everyone,
Our developers has already fixed the reported compatibility issues with the newest WooCommerce version and the permanent fix will be available in the next Themler update.
Sorry for the inconvenience.
Ivan
Hi everyone, Our developers has already fixed the reported compatibility issues with the newest WooCommerce version and the permanent fix will be available in the next Themler update. Sorry for the inconvenience. Thanks, Ivan
anthony
anthony posted this 16 June 2016
Support when is the next update expected to be pushed and how does one know that their template has been updated to the correct version prior to updating WooCommerce?
Support Team posted this 17 June 2016
We plan to include this fix in one of the future Themler updates. Usually the update topic contains a list if fixes. Currently I cannot say the exact version number. Most probably it will be included into the upcoming public update or into a next hot-fix update.
Hi, We plan to include this fix in one of the future Themler updates. Usually the update topic contains a list if fixes. Currently I cannot say the exact version number. Most probably it will be included into the upcoming public update or into a next hot-fix update. Thank you, Olivia
info1784
info1784 posted this 21 June 2016
Same Problem here unfortunately... hope to get updated soon.
