Vertical menu 2nd and 3rd level are the same
webmaster@exnet.gr
webmaster@exnet.gr posted this 15 June 2016
I want to change the layout of vertical menu levels. As you can see on the link I am sending you, the 2nd and the 3rd level has the same layout. How can I do that?
http://joxi.ru/brR5xD7UQqbppA
http://marb.gr/wp-admin
username: themler
Password: themler
Thanks in advance!
Hello, I want to change the layout of vertical menu levels. As you can see on the link I am sending you, the 2nd and the 3rd level has the same layout. How can I do that? http://joxi.ru/brR5xD7UQqbppA http://marb.gr/wp-admin username: themler Password: themler Thanks in advance!
Support Team posted this 15 June 2016
You can design the second level only. Use the Submenus options under the Vertical Menu settings. The lower levels can not be adjusted.
Hi, You can design the second level only. Use the Submenus options under the Vertical Menu settings. The lower levels can not be adjusted. Sincerely, Hella
Sem
Sem posted this 26 March 2019
This is a big issue, when you can't have 3rd level on vertical menu.
Sam time 2nd and 3rd levels looks the same way.
This is really big issue when you are working with eCommerce shops and information based websites.
If you are providing woocommerce feature then you need to take care also about this part.
Is there any way to make this fixed ?
This is a big issue, when you can't have 3rd level on vertical menu. Sam time 2nd and 3rd levels looks the same way. This is really big issue when you are working with eCommerce shops and information based websites. If you are providing woocommerce feature then you need to take care also about this part. Is there any way to make this fixed ?
