Drupal theme no longer updating when published to live site
stephen17
stephen17 posted this 18 June 2016
I updated Drupal core to 7.44 and the Themeler designer is no longer publishing changes over to the main site. I'm using the Themeler module on the site to work on the theme. I can make and see changes and save them in the design tool, but they don't publish to the live site. Is there an issue with the new Drupal core? Is there a fix or workaround? I'm stuck.
Thanks in advance for the help.
I updated Drupal core to 7.44 and the Themeler designer is no longer publishing changes over to the main site. I'm using the Themeler module on the site to work on the theme. I can make and see changes and save them in the design tool, but they don't publish to the live site. Is there an issue with the new Drupal core? Is there a fix or workaround? I'm stuck. Thanks in advance for the help.
stephen17
SOLVED: Udated Themeler and theme to latest Themeler and all is well again.
