How do I start with a fresh theme
musicalimage
musicalimage posted this 20 June 2016
I had designed a theme in using Joomla CMS and now I am starting a new theme for a completely different customer. When I create the new theme it still has the pages and content from the other theme. What should I do? Can I delete these pages or am I creating a new theme incorrectly?
Teclis16
Teclis16 posted this 21 June 2016
I have the same problem :(
Support Team posted this 22 June 2016
Themler desktop works on the dummy site installed on your computer. You can remove the site installation each time you start the new project so it will erase the content and create a new CMS installation. For that remove the following folder:
C:\ProgramData\Themler\hd_data\themler_[numbers]\joomla
Hi, Themler desktop works on the dummy site installed on your computer. You can remove the site installation each time you start the new project so it will erase the content and create a new CMS installation. For that remove the following folder: C:\ProgramData\Themler\hd_data\themler_[numbers]\joomla Sincerely, Hella
Carlos
Carlos posted this 12 October 2017
I have the same problem but with wordpress, it adds the pages from the last theme and I have had to redesign the template three times.
Hi, I have the same problem but with wordpress, it adds the pages from the last theme and I have had to redesign the template three times. Thanks Regards
Support Team posted this 16 October 2017
As explained above, you can remove the C:\ProgramData\Themler\hd_data\themler_[numbers]\wordpress folder each time you start a new project.
Hi, As explained above, you can remove the `C:\ProgramData\Themler\hd_data\themler_[numbers]\wordpress` folder each time you start a new project. Sincerely, Hella
DaveOzric
DaveOzric posted this 17 October 2017
Well it would do this since it's a local install of the CMS using the Desktop version of Themler.
