prevent responsive menu animation
Marcus Anderson
Marcus Anderson posted this 21 June 2016
I'd like to remove the built in animation when expanding the responsive menu.
Can you tell me how to do this please?
Hi, I'd like to remove the built in animation when expanding the responsive menu. Can you tell me how to do this please?
I do not see any animation, please provide more details what you are talking about.
Hi, I do not see any animation, please provide more details what you are talking about. Sincerely, Hella
Marcus Anderson
Hi Hella,
There's a transition effect when pressing the menu button when in responsive mode.
You press the menu button and it takes about a second for the menu to expand open.
This is the animation I'm talking about: the transition effect of the menu opening.
I would like to remove this transition effect.
Hi Hella, There's a transition effect when pressing the menu button when in responsive mode. You press the menu button and it takes about a second for the menu to expand open. This is the animation I'm talking about: the transition effect of the menu opening. I would like to remove this transition effect.
Support Team posted this 23 June 2016
No, there is no such possibility to control the opening of the menu in responsive. You see the long delay within Themler or on the live site? It should not take long on the site. You can provide a link to it so we could see the problem.
Hi, No, there is no such possibility to control the opening of the menu in responsive. You see the long delay within Themler or on the live site? It should not take long on the site. You can provide a link to it so we could see the problem. Sincerely, Hella
Marcus Anderson
Marcus Anderson posted this 23 June 2016
Hi Hella,
If I can't use my own transition effects, so be it - I'll stop trying to use my own and stick with it how it is.
Hi Hella, If I can't use my own transition effects, so be it - I'll stop trying to use my own and stick with it how it is.
Yes, that will be a better solution. Please let us know if you need our further help.
Hi, Yes, that will be a better solution. Please let us know if you need our further help. Sincerely, Hella
