Woocommerce 'proceed to checkout'-button
anneke
anneke posted this 13 March 2015
Is it possible to change the position of the ''proceed to checkout'-button?
Because I would like to see it at the bottom of the content. And can I translate this button in Billionthemler? Or should I do this in certain .php file?
Thanks in advance,
Paul
Hi, Is it possible to change the position of the ''proceed to checkout'-button? Because I would like to see it at the bottom of the content. And can I translate this button in Billionthemler? Or should I do this in certain .php file? Thanks in advance, Paul
6 Comments
chermus
chermus posted this 13 March 2015
Anneke,
The Proceed to checkout button is standard Woocommerce text, with Multilingual plugins or other Woocommerce translations you are able to change this text. This is not a text setup in Themler.
For changing the position and size click on the Cart, then click on the "proceed to checkout" button
Then Goto the Shape options (cogwheel) on the left panel.
Select the re-size icon and play around with positioning to suit your needs.
Anneke, The Proceed to checkout button is standard Woocommerce text, with Multilingual plugins or other Woocommerce translations you are able to change this text. This is not a text setup in Themler. For changing the position and size click on the Cart, then click on the "proceed to checkout" button !Select-Checkout-button.JPG! Then Goto the Shape options (cogwheel) on the left panel. !Select-Options.JPG! Select the re-size icon and play around with positioning to suit your needs. !Select-Sizing-and-positions.JPG!
anneke
anneke posted this 16 March 2015
Thanks for your respond. But I actually mean to remove the button to the bottom of the page (see the attachment).
I think it's better for the usability to remove the checkout button to the bottom.
Kind regards,
Thanks for your respond. But I actually mean to remove the button to the bottom of the page (see the attachment). I think it's better for the usability to remove the checkout button to the bottom. Kind regards,
Support Team posted this 16 March 2015
Hello Anneke,
currently it's not possible to move the 'Proceed to Checkout' button to the bottom of the Shopping Cart template.
However I'll add it to our wish list.
Hello Anneke, currently it's not possible to move the 'Proceed to Checkout' button to the bottom of the Shopping Cart template. However I'll add it to our wish list. Regards, Aileen
anneke
Thanks! Think this should be a great improvement!
Hello Anneke,
Thanks! Think this should be a great improvement! > Hello Anneke, > currently it's not possible to move the 'Proceed to Checkout' button to the bottom of the Shopping Cart template. > However I'll add it to our wish list. > > Regards, > Aileen
Gwe Cambrian Web
Gwe Cambrian Web posted this 26 September 2018
Hi there, did this ever get implemented?
Support Team posted this 27 September 2018
Hi Gwe Cambrian Web,
No, unfortunately. We have not moved this button in Themler themes.
Hi Gwe Cambrian Web, No, unfortunately. We have not moved this button in Themler themes. Thank you, Olivia
