ideales magento theme
marco.marino1971
marco.marino1971 posted this 22 June 2016
I am customizing a magento theme form billionthemes. It is "Ideales" magento theme:
selectedCms=Magento&statisticsID=45187537&containsInPage=False">http://templates.themler.com/Themes/Detail/1888876/Ideales?selectedCms=Magento&statisticsID=45187537&containsInPage=False
I uploaded the theme here: http://kokomamas.ilbello.com/
I do not really understand how some effects and "image+text" columns are built.
There is a row with 4 coloumns. Each of the 4 columns contain image+text and it seems only content has been used (no image, no header of the image+content block).
Questions:
1)On mouse hover the squared column becomes rounded and also the button inside it. But in backend themler I do not found where this effect has been creted/applied. do you know how?
2) In each "text+image" block there is a title (for example "Our House") that seems to be H3. As I try to modify the word (for example I tried to write "Nuovi arrivi" in the second column) I loose the H3 style and do not understand how to apply again.
3) Under the "Our House" H3 text in the first columns there is a line separating the title form the lower text, but how this line has been made? I am not able to apply the same line in the other columns (these lines have been lost as I tried to modify the text)
I use themler since more than one year and never found such problems in customizing image + text,
can you give me any suggestions?
I think you can understand my problems as you log into online themler theme and try to change some text in the columns
Marco
I am customizing a magento theme form billionthemes. It is "Ideales" magento theme: [http://templates.themler.com/Themes/Detail/1888876/Ideales?selectedCms=Magento&statisticsID=45187537&containsInPage=False][1] I uploaded the theme here: [http://kokomamas.ilbello.com/][2] I do not really understand how some effects and "image+text" columns are built. There is a row with 4 coloumns. Each of the 4 columns contain image+text and it seems only content has been used (no image, no header of the image+content block). Questions: 1)On mouse hover the squared column becomes rounded and also the button inside it. But in backend themler I do not found where this effect has been creted/applied. do you know how? 2) In each "text+image" block there is a title (for example "Our House") that seems to be H3. As I try to modify the word (for example I tried to write "Nuovi arrivi" in the second column) I loose the H3 style and do not understand how to apply again. 3) Under the "Our House" H3 text in the first columns there is a line separating the title form the lower text, but how this line has been made? I am not able to apply the same line in the other columns (these lines have been lost as I tried to modify the text) I use themler since more than one year and never found such problems in customizing image + text, can you give me any suggestions? I think you can understand my problems as you log into online themler theme and try to change some text in the columns Regards Marco [1]: http://templates.themler.com/Themes/Detail/1888876/Ideales?!ideales-megento-theme2.jpg!selectedCms=Magento&statisticsID=45187537&containsInPage=False [2]: http://kokomamas.ilbello.com/
Support Team posted this 23 June 2016
1) For this effect the custom CSS code is used. You can see it in Home tab >> Settings >> Additional CSS.
2) I could sucessfully change the text, it won't loose the style. This text uses styles defined for H3 subtitle globally - in Design tab >> Fonts >> Styles >> Subtitle H3, the font is set for all Headings.
Please try to type the text "inside" the original one and then delete unnecessary text from left and right - it should be the same style for sure. Also please feel free to use Copy Style/Paste Style options in different cases.
3) This line is also made by extra CSS:
.text-group-banner-header
padding-bottom: 25px;
border-bottom: 1px solid #ccc;
Hello, 1) For this effect the custom CSS code is used. You can see it in Home tab >> Settings >> Additional CSS. 2) I could sucessfully change the text, it won't loose the style. This text uses styles defined for H3 subtitle globally - in Design tab >> Fonts >> Styles >> Subtitle H3, the font is set for all Headings. Please try to type the text "inside" the original one and then delete unnecessary text from left and right - it should be the same style for sure. Also please feel free to use Copy Style/Paste Style options in different cases. 3) This line is also made by extra CSS: .text-group-banner-header { padding-bottom: 25px; border-bottom: 1px solid #ccc; } Sincerely, Nettie, BillionDigital Team
