Edit in Themler in Post
webmaster@exnet.gr
webmaster@exnet.gr posted this 23 June 2016
Hello, after last updates in themler there is new button in posts: "Edit in Themler" (http://joxi.ru/vAWXL6DSkNVyNr), i would like to not have this button for the authors of my sites. How can i disable this option for a particular role in my sites?
Thank you in advance.
Hello, after last updates in themler there is new button in posts: "Edit in Themler" (http://joxi.ru/vAWXL6DSkNVyNr), i would like to not have this button for the authors of my sites. How can i disable this option for a particular role in my sites? Thank you in advance.
8 Comments
Support Team posted this 28 June 2016
Hello Vladimiros,
I'm not quite sure that it is possible.
I'll ask developers and will let you know
Hello Vladimiros, I'm not quite sure that it is possible. I'll ask developers and will let you know regards, Aileen
Sct Design Group
Sct Design Group posted this 28 June 2016
Turn Off the Plugin after edits are done (themler-core)
webmaster@exnet.gr
webmaster@exnet.gr posted this 06 July 2016
Hello Sct Design Group,
how can i do that?
Thank you.
Hello Sct Design Group, how can i do that? Thank you.
Support Team posted this 06 July 2016
This is regular WP plug-in and you can disable it or uninstall under the WP plug-ins. Please note that this plugin processes shortcodes. If you\re using theme shortcode they will not be processed without plug-in.
As alternative solution you can download theme without Themler after edits and install it instead of the theme with Themler. In this case "Edit in Themler" and "Start Themler" options will not appear.
Hi, This is regular WP plug-in and you can disable it or uninstall under the WP plug-ins. Please note that this plugin processes shortcodes. If you\re using theme shortcode they will not be processed without plug-in. As alternative solution you can download theme without Themler after edits and install it instead of the theme with Themler. In this case "Edit in Themler" and "Start Themler" options will not appear. Thank you, Olivia
jau
jau posted this 09 February 2017
I would be a really good thing if we had a "disable Themeler in post editor" option.
In some cases, it's a BIG waste of time to be forced to edit a theme locally and upload, even for some small change !
thx
Hi, I would be a really good thing if we had a "disable Themeler in post editor" option. In some cases, it's a BIG waste of time to be forced to edit a theme locally and upload, even for some small change ! thx
Support Team posted this 10 February 2017
We'll consider your suggestion for the possible future implementations.
Hi, We'll consider your suggestion for the possible future implementations. Sincerely, Hella
Lex
Lex posted this 27 December 2018
Hi.
i have the same Problem in the new Wordpress Version.
How can i remove/invisible this "Edit in Themler" Button in Page/Posts ?
I can only disable the Button on the left Admin sidebar with this
https://answers.themler.io/questions/67176/disable-content-editing
or with User Role Editors
The button should only be visible to the Tech Admin / Webmaster and not to the customer
Thanks.
Hi. i have the same Problem in the new Wordpress Version. How can i remove/invisible this "Edit in Themler" Button in Page/Posts ? I can only disable the Button on the left Admin sidebar with this https://answers.themler.io/questions/67176/disable-content-editing or with User Role Editors The button should only be visible to the Tech Admin / Webmaster and not to the customer Thanks.
Support Team posted this 27 December 2018
Unfortunately, Themler does not provide such functionality. But the button should not be visible if you install the theme without Themler.
Hi, Unfortunately, Themler does not provide such functionality. But the button should not be visible if you install the theme without Themler. Sincerely, Olivia
