Themler + Phoca PDF
webworker
webworker posted this 08 July 2016
Is a Themler Template working with Phoca PDF?
How or where i can insert the following lines http://www.phoca.cz/documents/47-phoca-pdf-component/812-phoca-pdf-installation-and-usage-joomla-3-3
Many thx
Nadine
Is a Themler Template working with Phoca PDF? How or where i can insert the following lines http://www.phoca.cz/documents/47-phoca-pdf-component/812-phoca-pdf-installation-and-usage-joomla-3-3 Many thx Nadine
8 Comments
Support Team posted this 11 July 2016
I'll ask our developers about the place where this code should be inserted.
We'll let you know when we receive any news from them.
Hi, I'll ask our developers about the place where this code should be inserted. We'll let you know when we receive any news from them. Thank you, Olivia
webworker
webworker posted this 11 July 2016
Many thx pls asap.
Nadine
Many thx pls asap. Nadine
We'll let you know as soon as there is any respond from our developers.
We'll let you know as soon as there is any respond from our developers. Sincerely, Hella
Support Team posted this 13 July 2016
Please try the following solution:
1. open <theme_name>/html/com_content/article/default.php file
2. find the line:
Designer::load("Designer_Content");
3. add the following code right after the line above:
$phocaPDF = false;
if (JPluginHelper::isEnabled('phocapdf', 'content')) {
include_once(JPATH_ADMINISTRATOR . '/components/com_phocapdf/helpers/phocapdf.php');
$GLOBALS['phocaPDF'] = PhocaPDFHelper::getPhocaPDFContentIcon($this->item, $this->item->params);
4. then go to Themler >> Post Template and add CMS Code control to the place where you want the icon to appear:
<?php
if (isset($GLOBALS['phocaPDF']))
echo $GLOBALS['phocaPDF'];
CMS Code control is available under the Insert tab >> More.
Hi, Please try the following solution: 1. open `<theme_name>/html/com_content/article/default.php` file 2. find the line: `Designer::load("Designer_Content");` 3. add the following code right after the line above: `$phocaPDF = false; if (JPluginHelper::isEnabled('phocapdf', 'content')) { include_once(JPATH_ADMINISTRATOR . '/components/com_phocapdf/helpers/phocapdf.php'); $GLOBALS['phocaPDF'] = PhocaPDFHelper::getPhocaPDFContentIcon($this->item, $this->item->params); }` 4. then go to Themler >> Post Template and add CMS Code control to the place where you want the icon to appear: `<?php if (isset($GLOBALS['phocaPDF'])) echo $GLOBALS['phocaPDF']; ?>` !insert-cms-code.png! **CMS Code** control is available under the Insert tab >> More. Thank you, Olivia
webworker
webworker posted this 14 July 2016
Hi.
Thank you very much its working fine:)
Nadine
Hi. Thank you very much its working fine:) Nadine
Support Team posted this 15 July 2016
You are welcome, feel free to contact us in any other occasion.
You are welcome, feel free to contact us in any other occasion. Sincerely, Hella
themler44
themler44 posted this 3 weeks ago
Hallo, vielen Dank für diesen Tipp!
Gibt es (künftig) eine Möglichkeit, diesen Code dauerhaft in Themler zu involvieren, so das man nicht immer die /article/default.php bearbeiten muß?
mfg
Hello, thank you for this tip!
Is there a way to involve this code permanently in Themler, so you do not always have to edit /article/default.php?
Kind regards
Hallo, vielen Dank für diesen Tipp! Gibt es (künftig) eine Möglichkeit, diesen Code dauerhaft in Themler zu involvieren, so das man nicht immer die /article/default.php bearbeiten muß? mfg ========================================================================== Hello, thank you for this tip! Is there a way to involve this code permanently in Themler, so you do not always have to edit /article/default.php? Kind regards
We do not have plans to include this code in the theme as not all our users need Phoca PDF plug-in. Please feel free to use the provided workaround. Unfortunately you will need to edit the exported files each time you save the theme.
Hi, We do not have plans to include this code in the theme as not all our users need Phoca PDF plug-in. Please feel free to use the provided workaround. Unfortunately you will need to edit the exported files each time you save the theme. Sincerely, Hella
