Can't Style Button inside a widget
shaulhadar
shaulhadar posted this 10 July 2016
Hello Themler Team. I am trying to style a button of a contact form 7 widget in wordpress.
I tried to use themler for the styling of the button, but actually if i go to to style it nothing shows, as if its now included in the options.
Is there any way else to do this?
if not, please fix this asap, this means i can't style any of my widget areas in wordpress like i need.
Thanks for your time,
Shaul.
Hello Themler Team. I am trying to style a button of a contact form 7 widget in wordpress. I tried to use themler for the styling of the button, but actually if i go to to style it nothing shows, as if its now included in the options. Is there any way else to do this? if not, please fix this asap, this means i can't style any of my widget areas in wordpress like i need. Thanks for your time, Shaul.
10 Comments
Support Team posted this 11 July 2016
In such forms the button inherits the global button style. The button style is set in the Design tab >> Button. Please let us know if the changes are not applied.
Hello, In such forms the button inherits the global button style. The button style is set in the Design tab >> Button. Please let us know if the changes are not applied. Sincerely, Nettie, BillionDigital Team
shaulhadar
shaulhadar posted this 12 July 2016
Hi Nettie, thanks for getting back to me.
I am aware that a widget will take the button default style and use it. I am talking about having a different style in the widget, and a different style as a default. In every professional software like this you have the option to change multiple button styles, its a standard. another thing, this was working on older themler versions, so why not now?
also, there is a very big bug, in which when you press "more options" nothing shows. this is where you are supposed to get those options for editins, yet now when you press it , it defaults to the widget style, and you can't style the button.
I hope you understand better now...please talk with the developers, because currently this option is not working and it was working before..
thanks for your time :)
Shaul.
Hi Nettie, thanks for getting back to me. I am aware that a widget will take the button default style and use it. I am talking about having a different style in the widget, and a different style as a default. In every professional software like this you have the option to change multiple button styles, its a standard. another thing, this was working on older themler versions, so why not now? also, there is a very big bug, in which when you press "more options" nothing shows. this is where you are supposed to get those options for editins, yet now when you press it , it defaults to the widget style, and you can't style the button. I hope you understand better now...please talk with the developers, because currently this option is not working and it was working before.. thanks for your time :) Shaul.
Support Team posted this 12 July 2016
Hello Shaul,
Thanks for details, I see now what you mean and can reproduce the issue. Indeed, there are no options for styling buttons in a widget area (except for presets). Still the "More Option" link leads to the widget area extended options as in the old versions. So the issue is related to Button options missing, and I have asked our developers about it.
Hello Shaul, Thanks for details, I see now what you mean and can reproduce the issue. Indeed, there are no options for styling buttons in a widget area (except for presets). Still the "More Option" link leads to the widget area extended options as in the old versions. So the issue is related to Button options missing, and I have asked our developers about it. Sincerely, Nettie, BillionDigital Team
Support Team posted this 25 July 2016
Hi Shaul,
Our developers have fixed the issue and the fix will be included in the next update.
Hi Shaul, Our developers have fixed the issue and the fix will be included in the next update. Sincerely, Nettie, BillionDigital Team
shaulhadar
shaulhadar posted this 02 August 2016
Hi Nettie!
Thanks for the update :)
Hi Nettie! Thanks for the update :)
Support Team posted this 02 August 2016
Shaul, you are welcome!
Netie,
Shaul, you are welcome! Sincerely, Netie, BillionDigital Team
Gillips
Gillips posted this 24 August 2017
I'm using v256 in Chrome and can't seem to style buttons within forms in my Joomla template. Is this a software bug? Thanks.
Support Team posted this 24 August 2017
By default forms should have the styles set in teh Design tab >> Styles >> More Styles for Forms. If they doesn't, please create a new private topic and attach the theme exported with content for investigation. Or provide temporary access to your website if possible.
Sincerel,y
Hello, By default forms should have the styles set in teh Design tab >> Styles >> More Styles for Forms. If they doesn't, please create a new private topic and attach the theme exported with content for investigation. Or provide temporary access to your website if possible. Sincerel,y Nettie, BillionDigital Team
Gillips
Gillips posted this 25 August 2017
Thanks. At Design tab >> Styles >> More Styles for Forms my button is green but on my site it remains blue. I will start a private topic then.
Support Team posted this 25 August 2017
Ok, let's continue in the private case.
Hello, Ok, let's continue in the private case. Sincerely, Nettie, BillionDigital Team
