HMENU each item a different color?
dg24
dg24 posted this 13 July 2016
Dear Themler Team,
is it somehow possible in Themler to give each HMENU entry a different background color (active, hover, normal) and height just as it has been done here:
enter image description here
Best regards,
Dan
Dear Themler Team, is it somehow possible in Themler to give each HMENU entry a different background color (active, hover, normal) and height just as it has been done here: ![enter image description here][1] Best regards, Dan [1]: http://www.flashmint.com/template-preview/004526.jpg
Support Team posted this 13 July 2016
There is no such possibility in the application. You can try to use the custom code. For that open the live site and find the unique class names for each menu item and then change the background color and padding as desired. Custom code can be included under the Home >> Settings >> Additional CSS.
Hi, There is no such possibility in the application. You can try to use the custom code. For that open the live site and find the unique class names for each menu item and then change the background color and padding as desired. Custom code can be included under the Home >> Settings >> Additional CSS. Sincerely, Hella
dg24
Hi Hella,
thanks alot for the quick reply. I will try that and see if it works, but maybe including a Themler function here would be pretty useful, considering the posibilites (also different icons for different entries and stuff)
Best regards,
Dan
Hi Hella, thanks alot for the quick reply. I will try that and see if it works, but maybe including a Themler function here would be pretty useful, considering the posibilites (also different icons for different entries and stuff) Best regards, Dan
Thanks for the suggestion, I'll add it to our wish list for possible future implementations.
Thanks for the suggestion, I'll add it to our wish list for possible future implementations. Sincerely, Hella
