Product Type / Themler Page
Amilcar Botelho Rubim Junior
Amilcar Botelho Rubim Junior posted this 18 July 2016
What are the items that are in Product Type / Themler Page.
At this point it appears several templetes / models and has downlod html fre.
But in fact it is not only the html templetes / models are js and css but and could not see the templetes / models proposed.
Att..
Amilcar
What are the items that are in Product Type / Themler Page. At this point it appears several templetes / models and has downlod html fre. But in fact it is not only the html templetes / models are js and css but and could not see the templetes / models proposed. Att.. Amilcar
Support Team posted this 19 July 2016
Themler Page is the example of how several sections could form the page. You can download each section separately and then import in any other section in Themler.
Hi, Themler Page is the example of how several sections could form the page. You can download each section separately and then import in any other section in Themler. Sincerely, Hella
Amilcar Botelho Rubim Junior posted this 19 July 2016
But how do I do this import?
Att..
Amilcar
But how do I do this import? Att.. Amilcar
Support Team posted this 20 July 2016
You can go to Insert >> Section (from Library) and that will open the list of the available sections from BillionThemes. Choose the one you like and it will be included in your theme.
Also you can download each section as a .zip file when you view the page in BillionThemes and then insert a blank section in Themler and use Upload from .zip.
Hi, You can go to Insert >> Section (from Library) and that will open the list of the available sections from BillionThemes. Choose the one you like and it will be included in your theme. Also you can download each section as a .zip file when you view the page in BillionThemes and then insert a blank section in Themler and use Upload from .zip. Sincerely, Hella
