bookmark list (bullet list)
Amilcar Botelho Rubim Junior
Amilcar Botelho Rubim Junior posted this 20 July 2016
The list of bookmarks does not appear.
Defined in sections / more style / bullet style / icon
And the set icon appears in front of the text items.
Att..
Amilcar
The list of bookmarks does not appear. Defined in sections / more style / bullet style / icon And the set icon appears in front of the text items. Att.. Amilcar
13 Comments
greg41
greg41 posted this 20 July 2016
Could you please attach the screenshot with your settings?
Hello, Could you please attach the screenshot with your settings?
The following file
The following file
Support Team posted this 21 July 2016
Please attach your exported theme with the editor included.
Hi, Please attach your exported theme with the editor included. Sincerely, Hella
Amilcar Botelho Rubim Junior posted this 21 July 2016
The following site file
Amilcar
The following site file Amilcar
Support Team posted this 22 July 2016
Your items are not a list items so that's the reason why they do not take the bullets. Please redo the code so it will be the list and bullets should appear.
Hi, Your items are not a list items so that's the reason why they do not take the bullets. Please redo the code so it will be the list and bullets should appear. Sincerely, Hella
Amilcar Botelho Rubim Junior posted this 02 August 2016
Sorry, but I did not understand his explanation and still continue with this problem.
Could you explain me better how to solve.
Att..
Amilcar
Sorry, but I did not understand his explanation and still continue with this problem. Could you explain me better how to solve. Att.. Amilcar
Support Team posted this 02 August 2016
To make items look like a list, you need to use the HTML control, then press Edit HTML button and use the code like this:
<ul>
  <li>Coffee</li>
  <li>Tea</li>
  <li>Milk</li>
</ul>
Instead of Coffee and so on use your own list items text.
Now you have simple text that can not make the theme treat it as the list as there is no appropriate code.
Hi, To make items look like a list, you need to use the HTML control, then press Edit HTML button and use the code like this: <ul> <li>Coffee</li> <li>Tea</li> <li>Milk</li> </ul> Instead of Coffee and so on use your own list items text. Now you have simple text that can not make the theme treat it as the list as there is no appropriate code. Sincerely, Hella
Okay, but come
In any text editor is so, if I have a list of items one below the other, to select these items and click the correct icon, they are considered a list and still place an icon that I wish the left of the list.
So it is done in text editors (word) and is also done in Artisteer own.
Now here in Themler it is different, as I open the code in Themler to put the code was explicad me?
The stranger still see that in Themler own, have the option to do list by placing an icon to your left, then this function does not work I have to do the code in hand, is that right?
Att..
Amilcar
Okay, but come In any text editor is so, if I have a list of items one below the other, to select these items and click the correct icon, they are considered a list and still place an icon that I wish the left of the list. So it is done in text editors (word) and is also done in Artisteer own. Now here in Themler it is different, as I open the code in Themler to put the code was explicad me? The stranger still see that in Themler own, have the option to do list by placing an icon to your left, then this function does not work I have to do the code in hand, is that right? Att.. Amilcar
Support Team posted this 03 August 2016
to create custom bullet list in Themler add HTML control and use the same custom html code
<ul>
  <li>Coffee</li>
  <li>Tea</li>
  <li>Milk</li>
</ul>
Then use HTML control options to style bullet list
Namely to change the icon use the Image Option marked on screenshot
Hello, to create custom bullet list in Themler add HTML control and use the same custom html code <ul> <li>Coffee</li> <li>Tea</li> <li>Milk</li> </ul> !HTMLControl1.png! Then use HTML control options to style bullet list !HTMLControl2.png! Namely to change the icon use the Image Option marked on screenshot regards, Aileen
Amilcar Botelho Rubim Junior posted this 03 August 2016
In my menu does not have the option to edit HTML, as that provides this HTML editor.
See attached image.
Att..
Amilcar
In my menu does not have the option to edit HTML, as that provides this HTML editor. See attached image. Att.. Amilcar
It's because you need to use HTML control and not Text control. It can be found under Insert >> More tab.
Hi, It's because you need to use HTML control and not Text control. It can be found under Insert >> More tab. Sincerely, Hella
Amilcar Botelho Rubim Junior posted this 08 August 2016
OK
See my image attached.
I select an icon to appear on my list, but the selected icon appear.
What is the correct way for the icons to appear?
Att..
Amilcar
OK See my image attached. I select an icon to appear on my list, but the selected icon appear. What is the correct way for the icons to appear? Att.. Amilcar
Support Team posted this 08 August 2016
You have edited the More Styles options of the Section tab and not of the HTML. Please open the HTML tab first and then edit the More Styles options.
Hi, You have edited the More Styles options of the Section tab and not of the HTML. Please open the HTML tab first and then edit the More Styles options. Sincerely, Hella
