Menu Hover Effects
richard25
richard25 posted this 04 August 2016
Is it possible to create these types of Menu hover effects below using Themler? I can see the Transition effect but it seems somewhat restricted. I can also see a 'TRANSFORMS' option but the effect eg 'Rotate' is always greyed out.
https://codepen.io/Calloumi/pen/vndlH
Cheers
Hi Is it possible to create these types of Menu hover effects below using Themler? I can see the Transition effect but it seems somewhat restricted. I can also see a 'TRANSFORMS' option but the effect eg 'Rotate' is always greyed out. https://codepen.io/Calloumi/pen/vndlH Cheers
Support Team posted this 04 August 2016
Unfortunately there is no such possibility in Themler.
Hi, Unfortunately there is no such possibility in Themler. Sincerely, Hella
richard25
Might it be a feature later?
Cheers
Might it be a feature later? Cheers
Sure. I have changed the topic type to be a wishlist do other users will be also able to vote.
Hi, Sure. I have changed the topic type to be a wishlist do other users will be also able to vote. Sincerely, Hella
