Two horizontal menus beside each other
Dennisriise
Dennisriise posted this 09 August 2016
How can I make two horizontal menus beside each other on a Joomla template?
My customer has 6 menu items, and want the menu to be centered with his logo in the middle, so he has 3 menu items on each side of his logo.
I have tried with a three column section with joomla position on the left and right columt, and the image of the logo in the center column.
But when I apply menus to the right and left one, they appear as bulletlist, which is not what I want.
I hope this makes sense :)
How can I make two horizontal menus beside each other on a Joomla template? My customer has 6 menu items, and want the menu to be centered with his logo in the middle, so he has 3 menu items on each side of his logo. I have tried with a three column section with joomla position on the left and right columt, and the image of the logo in the center column. But when I apply menus to the right and left one, they appear as bulletlist, which is not what I want. I hope this makes sense :)
11 Comments
Support Team posted this 09 August 2016
You need to add 3 columns, use the center one for the logo and in two other columns insert the Horizontal Menu controls, they will have unique position names. Insert your menu modules in those positions.
Hi, You need to add 3 columns, use the center one for the logo and in two other columns insert the Horizontal Menu controls, they will have unique position names. Insert your menu modules in those positions. Sincerely, Hella
Dennisriise
Dennisriise posted this 10 August 2016
I have tried that, but they just seems to dublicate each other and will only repeat the same menuitems in both places.
Support Team posted this 10 August 2016
Have you created two different menus within Joomla? If that does not help, we would need an access to the site back end to review the settings.
Have you created two different menus within Joomla? If that does not help, we would need an access to the site back end to review the settings. Sincerely, Hella
Dennisriise
Ah, I see on the top left corner that I have to rename one of the positions, since themler give both positions the same name.
Everythings okay thanks :)
Ah, I see on the top left corner that I have to rename one of the positions, since themler give both positions the same name. Everythings okay thanks :)
Support Team posted this 11 August 2016
You are welcome. Nice to hear that it works fine.
You are welcome. Nice to hear that it works fine. Sincerely, Hella
Anammer
Anammer posted this 17 October 2016
Hello guys,
I would like to know if that's possible with wordpress too??
thank you
Hello guys, I would like to know if that's possible with wordpress too?? thank you
Support Team posted this 18 October 2016
Sure, the instructions are the same. You then should assign different menus for each menu position in your WP >> Appearance >> Menus.
Hi, Sure, the instructions are the same. You then should assign different menus for each menu position in your WP >> Appearance >> Menus. Sincerely, Hella
Anammer
Anammer posted this 18 October 2016
Thank you so much Hella, things are tested and work fine for desktop version. the issue now is that i got to menu for the mobile version. How to have a combine of the two menus in only one menu? is that possible?
thanks again
Hi, Thank you so much Hella, things are tested and work fine for desktop version. the issue now is that i got to menu for the mobile version. How to have a combine of the two menus in only one menu? is that possible? thanks again
Set the Display On option for the first two menus in Themler to be not visible in the phone modes. Then add one more new menu control and make it visible in the phone view only. Assign another menu within WP.
Hi, Set the Display On option for the first two menus in Themler to be not visible in the phone modes. Then add one more new menu control and make it visible in the phone view only. Assign another menu within WP. Sincerely, Hella
Anammer
Hi Hella,
very smart, thank you so much. will give it a try right now
thanks again,
Hi Hella, very smart, thank you so much. will give it a try right now thanks again,
Support Team posted this 19 October 2016
Let us know if you need our further help.
Let us know if you need our further help. Sincerely, Hella
