php extension for html pages
TJ Novick
TJ Novick posted this 14 August 2016
Just about every design program has the ability to change a page extension to .php enabling us to run form scripts etc. Until this is added is there a way to manually change the page extension? Also what about adding a ftp client? Am hoping Christmas will come early this year... Thanks
6 Comments
Stagger Lee posted this 14 August 2016
It is not possible. Themler will allways make and use .html extension. Your .php extension will be ignored and not editable by Themler.
TJ Novick
Wow that is a slight bummer, i guess I will have to use another program for my form and use inline frame then. :(
I believe html Themler has HTML control.
Support Team posted this 15 August 2016
Yes, you can use the HTML control from the Insert >> More tab.
Hi, Yes, you can use the HTML control from the Insert >> More tab. Sincerely, Hella
tomy3
tomy3 posted this 07 October 2017
I Insert html code i put:
<?php echo "hello";?>
but it save
<!--?php
And dosnt work.
Solution for this?.
Thank.
I Insert html code i put: &lt;?php echo &quot;hello&quot;;?&gt; but it save &lt;!--?php And dosnt work. Solution for this?. Thank.
Support Team posted this 09 October 2017
The HTML control adds the code to the generated page.html page. The php code will not work in this way. If you want to add php you will need to manually edit exported theme. Themler generates simple static html pages.
Also, HTML control does not support PHP code.
Hi, The HTML control adds the code to the generated page.html page. The php code will not work in this way. If you want to add php you will need to manually edit exported theme. Themler generates simple static html pages. Also, HTML control does not support PHP code. Thank you, Olivia
