Themler v.334 Beta Update (19-August-2016)
Support Team posted this 19 August 2016
Hi everyone,
The new Themler v.334 Beta is here!
Here is a list of fixes and features included in this beta update:
Controls
MegaMenu
MegaMenu is a new type of the existing Horizontal menu control. This type allows to display menu subitems in columns. It needs 3 levels of menu items.
Supported for Joomla, WP, Magento, PrestaShop and HTML.
In the future updates MegaMenu will be available for Drupal. We also plan to support inserting CMS modules/widgets/banners inside megamenu items.
enter image description here
This is beta version of MegaMenu. Therefore unexpected issues are possible.
Please let us know if there are any issues or suggestions.
UI
  • Improved Home tab. All theme settings have been moved to the Home tab.
  • Added Suggest options to the Home tab (see above). The suggestions are based on the library of Sections.
    Suggest Homepage - this feature uses Pages (a bunch of Content Section + Header and Footer Sections.).
    Suggest Blog - this feature uses Blog Sections. This option can be used for Blog Template only. If you're using it on any other template Themler will switch the current template to Blog.
  • All control related settings have been moved to the Edit tab.
  • Improved hover and selection of controls in preview area. Now hover and selection frames match each other.
    • Hover & Selection before:
    • Hover & Selection now:
Fixes
General
  • Fixed layout issues that appeared in the previous update.
  • Fixed a few issues with "Expand to Bottom" extension.
Drupal
  • Improved working with Custom templates. Now if you have created a template for custom content type and added a node of the appropriate type the Custom template will display this node in Themler. Previously, Custom templates have always shown the content of the Front Page.
Joomla
  • Fixed issue with print icon in Joomla 3.6
  • A few minor fixes
Wordpress
  • A few minor fixes
Themler Team
Hi everyone, The new Themler v.334 Beta is here! Here is a list of fixes and features included in this beta update: [post:94911] Thank you, Themler Team
10 Comments
pdg.design
pdg.design posted this 20 August 2016
Very good news!
The Themler is better and better!
Very good news! The Themler is better and better!
funmaking
funmaking posted this 20 August 2016
Nice!!
How can I design the megamenu with 2 columns of menu items?
I have 8 menu links submenu and I want to show them in 2 columns (4 + 4)
I have switched to Megamenu option and configured the columns options to 2 in Horizontal Menu - Columns but it's not working (it's a html theme).
Thanks!
Nice!! How can I design the megamenu with 2 columns of menu items? I have 8 menu links submenu and I want to show them in 2 columns (4 + 4) I have switched to Megamenu option and configured the columns options to 2 in Horizontal Menu - Columns but it's not working (it's a html theme). Thanks!
Bayern
Bayern posted this 20 August 2016
Joomla 3.6.2 Themler 334 PHP 7: cannot install Template
ERROR:
Fehler Unable to write entry Es kann kein Installationspaket gefunden werden!
What's to do?
Joomla 3.6.2 Themler 334 PHP 7: cannot install Template ERROR: Fehler Unable to write entry Es kann kein Installationspaket gefunden werden! What's to do?
Jorge
Jorge posted this 20 August 2016
for the future, the option to use icons in the menu?
menu icons
Hello, for the future, the option to use icons in the menu?![menu icons][1] [1]: http://i.imgur.com/oyZugVD.jpg
Kani
Kani posted this 21 August 2016
Like I said before, nothing can compare itself with Themler.
But, the all-time killer will be content editing in CMS.
Like I said before, nothing can compare itself with Themler. But, the all-time killer will be content editing in CMS.
Stagger Lee posted this 21 August 2016
Why there are double options for Megamenu ? Number of columns and custom width, both in Themler edit screen and in WordPress Menu options.
OK, they are for specific overrides.
Krav
Krav posted this 22 August 2016
Hi There,
Great news re the update!
How can I get and then apply the update to my theme?
Thanks in advance
Krav
Hi There, Great news re the update! How can I get and then apply the update to my theme? Thanks in advance Krav
support12
support12 posted this 22 August 2016
1) Mega Menu - Cannot insert images in mega menu which is very latest and it has been apply before 3 yrs by other developer.
2) Please focus on mobile menu also check latest sites how they have prepared for latest mobile - responsive mode.
1) Mega Menu - Cannot insert images in mega menu which is very latest and it has been apply before 3 yrs by other developer. 2) Please focus on mobile menu also check latest sites how they have prepared for latest mobile - responsive mode.
Support Team posted this 22 August 2016
tropicalserver,
What you you mean by not working?
If you have 8 subitems and at least one of these 8 submenus has subsubitem that megamenu mode should be enabled. In this case you just need to configure columns.
You need the structure of 3 Levels:
Item
- SubItem
-- SubSuIitem
Krav,
Please find more details on how to enable Beta Updates here.
support12,
  1. As mentioned in the initial topic we plan to implement this feature in the future.
  2. Could you please describe your request in some details? What exactly mobile menu feature you need?
    If responsive menu is enabled MegaMenu mode switches off and menu looks as regular responsive horizontal menu.
**tropicalserver**, > How can I design the megamenu with 2 columns of menu items? I have 8 menu links submenu and I want to show them in 2 columns (4 + 4) I have switched to Megamenu option and configured the columns options to 2 in Horizontal Menu - Columns but it's not working (it's a html theme). What you you mean by not working? If you have 8 subitems and at least one of these 8 submenus has subsubitem that megamenu mode should be enabled. In this case you just need to configure columns. You need the structure of 3 Levels: Item - SubItem -- SubSuIitem **Krav,** Please find more details on how to enable Beta Updates [here](page:53794). **support12,** 1. As mentioned in the initial topic we plan to implement this feature in the future. 2. Could you please describe your request in some details? What exactly mobile menu feature you need? If responsive menu is enabled MegaMenu mode switches off and menu looks as regular responsive horizontal menu. Thank you, Olivia
