Set Image Margins
DaveOzric
DaveOzric posted this 20 August 2016
I am changing a bunch of themes from Artisteer to Themler and notice that images had a default margin set in Artisteer that I did not set personally. However in Themler it's 0 and my text is now up against the images.
Where is the setting to fix this in Themler if there is one?
I am changing a bunch of themes from Artisteer to Themler and notice that images had a default margin set in Artisteer that I did not set personally. However in Themler it's 0 and my text is now up against the images. Where is the setting to fix this in Themler if there is one? Thanks
6 Comments
DaveOzric
DaveOzric posted this 23 August 2016
Anyone?
Anyone?
Support Team posted this 24 August 2016
Hello Dave,
I'm sorry for delay in response.
If you're using the latest Artisteer version http://files3.artisteer.com/Artisteer.4.3.0.60928.exe then there's no fixes for the margins in Artisteer export.
Hello Dave, I'm sorry for delay in response. If you're using the latest Artisteer version http://files3.artisteer.com/Artisteer.4.3.0.60928.exe then there's no fixes for the margins in Artisteer export. regards, Aileen
DaveOzric
DaveOzric posted this 24 August 2016
You misunderstood, did not export anything.
Let's put it this way, my images in a new theme built with themler have no margin. Where do you set default margins for content photos?
My point was artisteer had some built in.
You misunderstood, did not export anything. Let's put it this way, my images in a new theme built with themler have no margin. Where do you set default margins for content photos? My point was artisteer had some built in.
Hello Dave,
the "default" margins for the Image control may be set under Design tab >> More Styles >> Image Style >> Margins
Hello Dave, the "default" margins for the Image control may be set under Design tab >> More Styles >> Image Style >> Margins !ImgMargin.png! regards, Aileen
Eric-P
Eric-P posted this 14 July 2017
Hello, it seems that the margins of the image work only if the type of image is not selected in bootstrap, therefore image of article in bootstrap remains in margin 0, you do not have an additional CSS code that Can add to have a margin.
gaatec
gaatec posted this 20 February 2018
"Better late than never. "
I had what I think was the same problem as Dave had.
To add a padding for all images I simply added the following CSS code under Home - Settings - Additional CSS
a img {
padding: 5px;
Hope this is of help to someone
"Better late than never. " I had what I think was the same problem as Dave had. To add a padding for all images I simply added the following CSS code under **Home - Settings - Additional CSS** a img { padding: 5px; } Hope this is of help to someone
