Themler v.340 Hot-Fix Update (26-August-2016)
Support Team posted this 26 August 2016
Here is a list of fixes included in v.340 Hot-Fix update:
  • Fix: green "+" adds Sections to template instead of page content;
  • Fix: issue with Positioning > Center by margins for some cases;
  • Fix: animation options are cut off under "Effects" submenu;
  • Fix: wrong Section height in some of existing projects;
  • Fix: crash on button selection in some cases;
We're still working on the issue with installing themes on Joomla 3.6.2 on some configurations.
If you receive the following error on installing theme in Joomla
Error
Unable to write entry
Unable to find install package
please either use a backup of the theme or unzip and pack the theme again. This should help.
We apologize for the inconvenience.
Themler Team
Hi, Here is a list of fixes included in v.340 Hot-Fix update: - Fix: green "+" adds Sections to template instead of page content; - Fix: issue with Positioning > Center by margins for some cases; - Fix: animation options are cut off under "Effects" submenu; - Fix: wrong Section height in some of existing projects; - Fix: crash on button selection in some cases; We're still working on the issue with installing themes on **Joomla 3.6.2** on some configurations. If you receive the following error on installing theme in Joomla > Error Unable to write entry Unable to find install package please either use a backup of the theme or unzip and pack the theme again. This should help. We apologize for the inconvenience. Thank you, Themler Team
9 Comments
pedja_792
pedja_792 posted this 26 August 2016
I use this options on Joomla 3.6.2 unzip and again zip. No more error messages.
Hi, I use this options on Joomla 3.6.2 unzip and again zip. No more error messages.
Dr. Dee
Dr. Dee posted this 28 August 2016
don't work it
after unzip and again zip I have same error
don't work it after unzip and again zip I have same error
dewald
dewald posted this 29 August 2016
Thank you for your hard work and prompt assistance. It seems that the "Article:" area is now below the footer...?
Thank you.
Thank you for your hard work and prompt assistance. It seems that the "Article:" area is now below the footer...? Thank you.
Albin Klein
Albin Klein posted this 29 August 2016
Sorry people but I am not happy, this is a big mess now, no info, no really FULL documentation of the changes, man really!
I have to change the whole website I was just designing because of this. Thank you anyway but I really hope this is for the best of the software.
Sorry people but I am not happy, this is a big mess now, no info, no really FULL documentation of the changes, man really! I have to change the whole website I was just designing because of this. Thank you anyway but I really hope this is for the best of the software.
Support Team posted this 29 August 2016
dewald,
If the issue happened after update please create a new Private topic and attach the theme backup (created before update).
Albin Klein,
This is hot fixes update with a few fixes for reported bugs.
What exactly documentation you need?
dewald, If the issue happened after update please create a new Private topic and attach the theme backup (created before update). Albin Klein, This is hot fixes update with a few fixes for reported bugs. What exactly documentation you need? Thank you, Olivia
Zierikzeker
Zierikzeker posted this 25 September 2016
Still not fixed....cant install any templates....need help quick!
Fout
Kan geen installatiepakket vinden.....
Still not fixed....cant install any templates....need help quick! Fout Kan geen installatiepakket vinden.....
Support Team posted this 27 September 2016
Zierikzeker,
Could you please create a new private topic and provide details about the issue you get when trying to install templates?
**Zierikzeker**, Could you please create a new private topic and provide details about the issue you get when trying to install templates? Sincerely, Nettie, BillionDigital Team
arifjamilm
arifjamilm posted this 21 June 2017
Warning
JInstaller: :Install: Can't find Joomla XML setup file.
Error
some details
Joomla version: 3.7.2.
Database Type: MySQLi
WEbserver: Apache/2.4.25 (Win32) OpenSSL/1.0.2j PHP/7.0.1
Themler: v.379
License type: Pro
**Warning** JInstaller: :Install: Can't find Joomla XML setup file. **Error** Unable to find install package **some details** Joomla version: *3.7.2.* Database Type: *MySQLi* WEbserver: *Apache/2.4.25 (Win32) OpenSSL/1.0.2j PHP/7.0.1* Themler: *v.379* License type: *Pro*
Support Team posted this 21 June 2017
arifjamilm,
Do you get this error when trying to import some previously exported theme? Make sure the theme is for "Themle for Joomla". Could you please provide some more details about how the theme was exported?
**arifjamilm**, Do you get this error when trying to import some previously exported theme? Make sure the theme is for "Themle for Joomla". Could you please provide some more details about how the theme was exported? Sincerely, Nettie, BillionDigital Team
