Mobile menu in all devices.
anneke
anneke posted this 08 April 2015
Is it possible (and how) to create an 'mobile menu icon' on all devices? So, it will show up on computer, tablet etc.?
See the attachment for some explanation of my idea.
Hi, Is it possible (and how) to create an 'mobile menu icon' on all devices? So, it will show up on computer, tablet etc.? See the attachment for some explanation of my idea.
Support Team posted this 08 April 2015
Unfortunately such feature is not supported at this time.
As a possible workaround you can try the following:
  1. create a menu which has only one first-level item without title and a number of subitems:
  2. set Font size to "0" and color equal to background color of the item in Themler. And add responsive icon.
    Note: this icon should have own size and color.
  3. disable responsive menu:
As the result you will get almost the same menu. the only difference that submenu will be opened on Hover, not on Click.
Hello Unfortunately such feature is not supported at this time. As a possible workaround you can try the following: 1. create a menu which has only one first-level item without title and a number of subitems: !resp-menu-1.png! 2. set Font size to "0" and color equal to background color of the item in Themler. And add responsive icon. **Note:** this icon should have own size and color. !resp-menu-2.png! 3. disable responsive menu: !resp-disable.png! As the result you will get almost the same menu. the only difference that submenu will be opened **on Hover**, not on Click. Thank you, Olivia
