Text area fields . New small feature.
Stagger Lee posted this 10 April 2015
Can you please just add this option, to prevent drag-drop resizing text areas, with mouse, outside container/block. So that is possible only to resize vertically. (resize:vertical)
To not to use fixed width of container in px. It makes other problems.
.wpcf7-textarea{
text-indent: 30px;
resize:vertical; }
Can you please just add this option, to prevent drag-drop resizing text areas, with mouse, outside container/block. So that is possible only to resize vertically. (resize:vertical) To not to use fixed width of container in px. It makes other problems. > .wpcf7-textarea{ > text-indent: 30px; > resize:vertical; }
shaulhadar
shaulhadar posted this 10 April 2015
Hi Stagger Lee, that's a great idea! I also have some troubles with the contact form 7 plugin, i think there needs to be more customization options for contact forms.... my biggest problem is actually that themler currently can't style the placeholder's text color, which makes most of my forms be without placeholders, which affects the design.. i wish there was some overhaul or cool update to all of these elements :)
Vote for it. Yes, we can. :)
Your wishes are bit different. This above is just example, Themler style for text area is good enough.
I see in code Themler has styling for placeholders, according to book and rules. Will check later what options are involved.
Vote for it. Yes, we can. :) Your wishes are bit different. This above is just example, Themler style for text area is good enough. I see in code Themler has styling for placeholders, according to book and rules. Will check later what options are involved.
Support Team posted this 10 April 2015
Hello guys,
If you're interested please vote for this feature.
We'll take into account each vote.
Hello guys, If you're interested please vote for this feature. We'll take into account each vote. Regards, Aileen
