How To Install PrestaShop Theme
To properly install a Themler Theme on PrestaShop Cloud, the "Import/export a theme" module is required. This is a native PrestaShop module which is available on PrestaShop Addons for free.
To install this module, it is necessary to register on PrestaShop Addons MarketPlace.
Then please install this module under the PrestaShop administration panel >> Modules >> Modules:
The installation of the Themler Theme on PrestaShop Cloud is the same as described in this article >> Install via Admin Panel (packed template).
The Usage of the Themler Theme on PrestaShop Cloud is the same as on self-hosted PrestaShop.
But there are two issues to consider when using Themler Theme on PrestaShop Cloud:
- If the following cache options are enabled under Performance settings, PrestaShop will constantly add cache files to to the /cache folder inside the theme directory:
This will increase the size of the theme folder and may cause performance problems while working with the theme in Themler (with applying changes, saving, downloading, etc.).
We suggest that you disable Smart Cache for CSS and JavaScript options while working with the theme in Themler.
- Also, it is recommended to enable SSL and Force the SSL on all the pages options under
Preferences:
### How To Install PrestaShop Theme
To properly install a Themler Theme on PrestaShop Cloud, the **"Import/export a theme"** module is required. This is a native PrestaShop module which is available on [PrestaShop Addons][1] for free.
To install this module, it is necessary to register on [PrestaShop Addons MarketPlace][2].
Then please install this module under the **PrestaShop administration panel** >> **Modules** >> **Modules**:
!ps-cloud-themeinstall.png!
The installation of the Themler Theme on PrestaShop Cloud is the same as described in [this article](page:3827) >> **Install via Admin Panel (packed template)**.
The Usage of the Themler Theme on PrestaShop Cloud is the same as on [self-hosted PrestaShop](page:3829).
<ol>
<li>If the following <b>cache options</b> are enabled under <b>Performance</b> settings, PrestaShop will constantly add cache files to to the <tt>/cache</tt> folder inside the theme directory:
<p><img src="http://attachments.answers.billiondigital.com/268/2268/ps-ccc-options.png"></p>
<p>This will increase the size of the theme folder and may cause performance problems while working with the theme in Themler (with applying changes, saving, downloading, etc.).</p>
<p>We suggest that you <b>disable Smart Cache for CSS and JavaScript</b> options while working with the theme in Themler.</p>
</li>
<li>Also, it is recommended to enable <b>SSL</b> and <b>Force the SSL on all the pages</b> options under <p>Preferences</b>:
<p>!ps-cloud-ssl.png!</p>
</li>
</ol>
[1]: http://addons.prestashop.com/en/front-office-features-prestashop-modules/1713-template-installer.html
[2]: http://addons.prestashop.com/
