- HTTPS support. Fixed issues with using Themler on SSL-secured websites.
- Added option to customize Background Image in specific responsive mode.
- Added "Custom CMS Code" option to theme Settings for Joomla and WordPress.
Controls and Effects
Added "CMS Code" control. This control allows you to execute custom CMS code on the page, e.g. PHP code.
Added "Smooth Wheel" page scrolling option to the theme Settings.
Now "Fix on Screen" option works with controls in Columns.
- Added option to match height of Columns in a Row with FlexBox (css solution):
Previously only a javascript solution was available.
WordPress and Woocommerce
- Added "Show Shortcode" control. Now you can insert plug-in's (Revolution Slider, Wow Slider, etc.) shortcodes directly in Themler:
- Fixed error display by adding Product Rating.
- Supported screen reader class for WP 4.2
- Removed extra shortcodes from Post Excerpts.
- Supported Menu Item css class (WP >> Appearance >> Menus >> open Screen Options to enable).
Joomla and VirtueMart
- The Product Description control was redesigned. Now it displays short product description on Products Template and full description on Product Details Template. Also it was removed from the Product Tabs on Product Details Template. Now you can add it to any place inside the Product Details control.
- Fixed issue with displaying Product Slider settings (under the joomla Template manager) if no VirtueMart installed.
- Fixed issue with outputting articles in the modal windows.
- Fixed crash on enabling Left Sidebar.
