  • Changes in Themler Subscriptions. Now Themler can be used after the subscription has expired. This only includes Themler versions which were released before the subscription expired. All updates after the subscription expiration date are paid.
  • Manual updates. Now the theme will not be updated automatically after each Themler update. You can choose whether you want to update the theme or not.
    NOTE: Right after this update all themes will be updated automatically. After the next update they can be updated manually.
  • The ability to load the Themler version that the theme was saved with for the last time.
  • No more Maintenance Message. You will be able to work with Themler while we update it.
  • Automatic backup. Starting with the next Themler update theme backup will be automatically created before every update.
  • AppCache technology is now supported. The theme traffic has been reduced by 30MB by caching Themler files (controls, presets, etc.) in the browser cache.
  • Reduced Themler startup time due to reduction of theme traffic.
  • Added Theme Management dialog. Now you can create a new theme, duplicate, rename, delete, switch between themes or upload an existing theme directly in Themler.
  • Added option to manage background-attachment (scroll/fixed) of the gradient and image separately.
  • Fixed issue with displaying Cart Link in RTL mode.
  • Added different View combinations of Cart Link text, total and icon:
  • Fixed issue with displaying Cart Link controls after closing Cart Link popup.
  • Fixed issue with opening and closing Vertical Menu subitems if "Expand with reload" option is selected.
  • Fixed the issue with adding padding to Hover Box control.
  • Theme localization is now merged with default WP dictionary (available for WP 4.0 and higher).
  • Posts Pagination now displays page numbers instead of Prev/Next buttons.
  • Changed Themler menu in WP admin panel.
WooCommerce
  • Fixed issue with opening Shopping Cart Template instead of Custom Template.
  • Removed extra bullets when outputting Product Review and Payment methods on Shopping Cart Template.
  • Added option to manage appearance of the Post Image Caption.
  • Fixed issue that appeared after enabling Conservative caching option.
  • Fixed issue with adding border radius to Post Image.
  • Fixed issue with applying Expand to Bottom Extension on 404 template.
What's Next?
We're working on Themler Desktop application. It will have minimum number of calls to our server. This will increase Themler speed.
### General - Changes in **Themler Subscriptions**. Now Themler can be used after the subscription has expired. This only includes Themler versions which were released before the subscription expired. All updates after the subscription expiration date are paid. - **Manual updates.** Now the theme will not be updated automatically after each Themler update. You can choose whether you want to update the theme or not. **NOTE: Right after this update all themes will be updated automatically. After the next update they can be updated manually.** - The ability to load the Themler version that the theme was saved with for the last time. - No more **Maintenance Message**. You will be able to work with Themler while we update it. - **Automatic backup**. Starting with the next Themler update theme backup will be automatically created before every update. !backup.png! - **AppCache technology** is now supported. The theme traffic has been reduced by 30MB by caching Themler files (controls, presets, etc.) in the browser cache. - Reduced Themler startup time due to reduction of theme traffic. - Added **Theme Management** dialog. Now you can create a new theme, duplicate, rename, delete, switch between themes or upload an existing theme directly in Themler. !theme-management.png! ## UI - Added option to manage background-attachment (scroll/fixed) of the gradient and image separately. ### Controls - Fixed issue with displaying Cart Link in RTL mode. - Added different View combinations of Cart Link text, total and icon: !cartlink-view.png! - Fixed issue with displaying Cart Link controls after closing Cart Link popup. - Fixed issue with opening and closing Vertical Menu subitems if "Expand with reload" option is selected. - Fixed the issue with adding padding to Hover Box control. #### WordPress - Theme localization is now merged with default WP dictionary (available for WP 4.0 and higher). - Posts Pagination now displays page numbers instead of Prev/Next buttons. - Changed Themler menu in WP admin panel. #### WooCommerce - Fixed issue with opening Shopping Cart Template instead of Custom Template. - Removed extra bullets when outputting Product Review and Payment methods on Shopping Cart Template. #### Joomla - Added option to manage appearance of the Post Image Caption. - Fixed issue that appeared after enabling *Conservative caching* option. #### Magento - Fixed issue with adding border radius to Post Image. - Fixed issue with applying **Expand to Bottom** Extension on 404 template. ### What's Next? We're working on **Themler Desktop** application. It will have minimum number of calls to our server. This will increase Themler speed.
