Desktop Installation Updated
We've updated Themler Desktop Installation to resolve the following issues:
- Fixed "Not found" error:
Not Found
The requested URL /themler_3383118731/startup/ was not found on this server.
Fixed issue with using Joomla in FireFox browser:
Not Found
/themler_3611916694/joomla\administrator/index.php
Fixed issue with establishing database connection error on slow/overloaded computers.
- Fixed installation for users having issues with PATH in Environment Variable.
- Improved Themler Diagnistics Tool.
Known issues:
- Desktop installer rarely crashes on start up.
Note: This update addresses issues with installing Themler Desktop on your computer only.
Joomla Artisteer Projects
You can finally import Joomla Artisteer projects directly into Themler.
- Download and install the updated version of Artisteer (Artisteer 4.3 license is required).
- Select "Themler" export type and "Joomla" CMS:
The downloaded Joomla theme can then be installed in joomla and opened in Themler in a usual way.
NOTE: These features are still in Beta stage, therefore unexpected issues are possible.
Please let us know about any issues that you encounter.
### Desktop Installation Updated
1. Fixed "Not found" error: <pre>Not Found
The requested URL /themler_3383118731/startup/ was not found on this server.</pre>
2. Fixed issue with using Joomla in FireFox browser: <pre>Not Found
/themler_3611916694/joomla\administrator/index.php</pre>
3. Fixed issue with establishing database connection error on slow/overloaded computers.
4. Fixed installation for users having issues with PATH in Environment Variable.
5. Improved Themler Diagnistics Tool.
**Known issues:**
**Note:** This update addresses issues with installing Themler Desktop on your computer only.
### Joomla Artisteer Projects
You can finally import **Joomla Artisteer projects** directly into Themler.
1. [Download][1] and install the updated version of Artisteer (Artisteer 4.3 license is required).
2. Select "Themler" export type and "Joomla" CMS:
!joomla-export.png!
The downloaded Joomla theme can then be [installed](page:3714) in joomla and [opened](page:3717) in Themler in a usual way.
Please [let us know][2] about any issues that you encounter.
[1]: http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
[2]: http://answers.themler.com/Topic/Create?private=1
