How To Install HTML Theme Without Themler
  1. Open the theme in Themler for editing.
  2. Navigate the File tab and select Export as ZIP.
  3. Unmark the "Include Themler for customizing this theme" checkbox.
  4. You will get the ready-to-use static HTML website which can be further uploaded to the webserver root or sub-directory.
How To Install HTML Theme With Themler
  1. To install HTML theme with Themler, please download Themler for HTML from our website.
    Alternatively, please follow the steps described above but leave the "Include Themler for customizing this theme" checkbox marked.
  2. You will get Themler editor and the theme.
    The theme is located in the /theme directory of the downloaded package.
  3. Unzip the downloaded package and upload it to your webserver's root directory (www, htdocs) or into a sub-directory if needed.
  4. Once you uploaded theme to the webserver you can start Themler by accessing the Themler editor with the following URL in the browser:
    http://host/[themler_folder]/themes/[theme_name]/__editor__/app.html
    NOTE: The theme name is Untitled by default. If you rename the theme in Themler then the theme name in the URL should be changed too.
    System requirements:
    • PHP 5.4+
Important: We strongly recommend to password protect the Themler editor folder /__editor__ to prevent unauthorized access to the content by a third party. Please refer to the following article for more details.
Learn More
How To Use HTML Themes
How To Password Protect Themler Editor
### How To Install HTML Theme Without Themler 1. Open the theme in Themler for editing. 2. Navigate the File tab and select **Export as ZIP**. 3. Unmark the "Include Themler for customizing this theme" checkbox. 4. You will get the **ready-to-use** static HTML website which can be further uploaded to the webserver root or sub-directory. ### How To Install HTML Theme With Themler 1. To install HTML theme with Themler, please download **Themler for HTML** from our [website][1]. Alternatively, please follow the steps described above but leave the "Include Themler for customizing this theme" checkbox marked. 2. You will get Themler editor and the theme. The theme is located in the <tt>/theme</tt> directory of the downloaded package. 3. Unzip the downloaded package and upload it to your webserver's root directory (www, htdocs) or into a sub-directory if needed. 4. Once you uploaded theme to the webserver you can start Themler by accessing the Themler editor with the following URL in the browser: <tt>http://host/[themler_folder]/themes/[theme_name]/&lowbar;&lowbar;editor&lowbar;&lowbar;/app.html</tt> **NOTE:** The theme name is *Untitled* by default. If you rename the theme in Themler then the theme name in the URL should be changed too. **System requirements:** - PHP 5.4+ <br/> <div class="alert alert-danger"> <b>Important:</b> We strongly recommend to password protect the Themler editor folder <b>/&lowbar;&lowbar;editor&lowbar;&lowbar;</b> to prevent unauthorized access to the content by a third party. Please refer to the following <a href="http://answers.themler.com/articles/26847">article</a> for more details. </div> ### Learn More [How To Use HTML Themes](page:24542) [How To Password Protect Themler Editor](page:26847) [1]: http://themler.com
