How to Edit Theme
How to Change Headline and Slogan Text
How to Change Logo Image
How to work with Drupal Regions
How to Create Horizontal Menu
How to manage Vertical Menu
How to manage Top Menu
How to Edit Theme
Once you have installed and enabled both the theme and the theme module, you can load Themler to edit the theme under the Drupal Appearance >> <Theme_Name> Settings:
NOTE: If you're using Drupal 6.x, please go to the Drupal Administer >> Site Building >> Themes >> find the basic theme >> click Configure and scroll page down >> click "Edit theme".
The text of the Headline and Slogan controls can be changed under the Drupal 7.x Configuration >> Site Information:
In Drupal 6.x, you can change the Headline and Slogan text under the Administer >> Site Configuration >> Site Information: Name and Slogan options.
The Logo control image specified in Themler can be overridden via the Drupal admin panel under the Appearance >> theme Settings.
To do this, please disable "Use the default logo" and specify the path or upload the image:
In Drupal 6.x, you can change the Logo image under the Drupal Administer >> Themes >> configue >> disable "Use the default logo" and specify the path or upload the image.
The Drupal theme consists of two themes: basic and preview.
You can see both of these themes under the Drupal Admin panel >> Appearance , for example;
- Untitled
- Untitled_preview
You will see the preview theme in the Themler preview area, and if you click Live Preview. This allows you to make changes to the theme and preview them in your browser without saving.
Therefore, if you assign any Drupal Blocks to the theme's regions, you should do it for both themes (basic and preview).
Also, when you add a new region in Themler we suggest that you clear Drupal cache under the Drupal Configuration >> Performance.
How to manage Horizontal Menu
Horizontal Menu is the main website navigation section.
To add a Horizontal menu to your website, you should add the Horizontal Menu control to a location where you would like to place the menu. This control creates a specific region (e.g. Horizontal Menu 1) where you can add a menu block in Drupal Structure >> Blocks.
Normally the Vertical Menu is a secondary website navigation section.
To add a Vertical Menu to your website, you should add the Vertical Menu Region control to a location where you would like to place the menu, This control creates a specific region (e.g. Vertical Menu 1) where you can add a menu block in Drupal Structure >> Blocks.
The Top Menu is an additional navigation menu normally used for internal website links (Login, My Account, etc.).
To add a Top Menu to your website, you should add the Top Menu control to a location where you would like to place the menu. This control creates a specific region (e.g. Top Menu 1) where you can add a menu block in Drupal Structure >> Blocks.
See also
Drupal Controls
[How to Edit Theme](#edit)
[How to Change Headline and Slogan Text](#headline_slogan)
[How to Change Logo Image](#logo)
[How to work with Drupal Regions](#regions)
[How to Create Horizontal Menu](page:5542)
[How to manage Vertical Menu](#vmenu)
[How to manage Top Menu](#tmenu)
<a id="edit"></a>
###How to Edit Theme
Once you have installed and enabled both the theme and the theme module, you can load Themler to edit the theme under the **Drupal Appearance** >> <Theme_Name> **Settings**:
!edit-Drupal-theme2.png!
**NOTE:** If you're using **Drupal 6.x**, please go to the **Drupal Administer** >> **Site Building** >> **Themes** >> find the basic theme >> click **Configure** and scroll page down >> click **"Edit theme"**.
<a id="headline_slogan"></a>
###How to Change Headline and Slogan Text
The text of the **Headline** and **Slogan** controls can be changed under the **Drupal 7.x Configuration** >> **Site Information**:
!headline-slogan.png!
In **Drupal 6.x**, you can change the Headline and Slogan text under the **Administer** >> **Site Configuration** >> **Site Information**: *Name* and *Slogan* options.
<a id="logo"></a>
###How to Change Logo Image
The Logo control image specified in Themler can be overridden via the Drupal admin panel under the **Appearance** >> theme **Settings**.
To do this, please disable *"Use the default logo"* and specify the path or upload the image:
!drupal-logo.png!
In **Drupal 6.x**, you can change the Logo image under the Drupal **Administer** >> **Themes** >> **configue** >> disable *"Use the default logo"* and specify the path or upload the image.
<a id="regions"></a>
### How to work with Drupal Regions
The Drupal theme consists of two themes: *basic* and *preview*.
- Untitled
- Untitled_preview
**Therefore, if you assign any Drupal Blocks to the theme's regions, you should do it for both themes (basic and preview).**
!drupal-menu.png!
Also, when you add a new region in Themler we suggest that you **clear Drupal cache** under the Drupal Configuration >> Performance.
<a id="hmenu"></a>
###How to manage Horizontal Menu
To add a Horizontal menu to your website, you should add the **Horizontal Menu control** to a location where you would like to place the menu. This control creates a specific region (e.g. *Horizontal Menu 1*) where you can add a menu block in Drupal **Structure** >> **Blocks**.
<a id="vmenu"></a>
###How to manage Vertical Menu
To add a Vertical Menu to your website, you should add the **Vertical Menu Region control** to a location where you would like to place the menu, This control creates a specific region (e.g. *Vertical Menu 1*) where you can add a menu block in Drupal **Structure** >> **Blocks**.
<a id="tmenu"></a>
###How to manage Top Menu
To add a Top Menu to your website, you should add the **Top Menu control** to a location where you would like to place the menu. This control creates a specific region (e.g. *Top Menu 1*) where you can add a menu block in Drupal **Structure** >> **Blocks**.
### See also
[Drupal Controls](page:5421)
