This tip describes how to show the posts from a specific category on the Home page.
Create new Page. This Page will be used as Front page:
Let's call it "Home".
Go to the WP Admin Panel >> Settings >> Reading and set this page as front page:
Now you should make so that Home page show the posts from the specific category. For this you need Category Slug.
Go to the WP Posts >> Categories >> find the Slug of the desired category:
Now go to the WP Pages >> find "Home" page >> click "Edit" >> find "Theme Options" block and enable "Show Custom Categories" option. In the field below specify the slug of the category:
Note: You can specify a single category Slug or a comma separated list of Slugs. leave empty to show all posts.
2. Create new Page. This Page will be used as Front page:
!wp-add-page.png!
1. Go to the **WP Admin Panel** >> **Settings** >> **Reading** and set this page as front page:
!wp-reading-settings.png!
3. Now you should make so that Home page show the posts from the specific category. For this you need **Category Slug**.
Go to the WP **Posts** >> **Categories** >> find the **Slug** of the desired category:
!wp-categories2.png!
4. Now go to the WP **Pages** >> find **"Home"** page >> click "Edit" >> find "**Theme Options**" block and enable "**Show Custom Categories**" option. In the field below specify the slug of the category:
!wp-categories1.png!
**Note:** You can specify a single category Slug or a comma separated list of Slugs. leave empty to show all posts.
