The Hook Top Column Control is a PrestaShop specific control that adds displayTop position, which usually contains the cart module and some useful links.
This control adds displayTop position to PrestaShop templates.
It can be found under Property Window >> Add Control >> Other >> Hook Top Column.
The Shape tab designs the entire hook area - to style the modules in this specific hook use the Block tab.
The modules can be managed from the PrestaShop back office >> Modules >> Positions. The displayTop hook shows the modules already added and the new modules can be inserted using the Transplant module option.
###Summary
The **Hook Top Column Control** is a [PrestaShop](http://answers.billiondigital.com/categories/3915/prestashop-3) specific control that adds **displayTop** position, which usually contains the cart module and some useful links.
###Usage
This control adds **displayTop** position to PrestaShop templates.
It can be found under **Property Window** >> **Add Control** >> **Other** >> **Hook Top Column**.
!hook-top-themler.png!
The **Shape** tab designs the entire hook area - to style the modules in this specific hook use the **Block** tab.
The modules can be managed from the **PrestaShop back office** >> **Modules** >> **Positions**. The **displayTop** hook shows the modules already added and the new modules can be inserted using the **Transplant module** option.
!hook-top.png!
