The Hook Left Column Control is a PrestaShop specific control that adds displayLeftColumn position, which usually contains the cart module and some modules with products.
This control adds displayLeftColumn position to PrestaShop templates.
It can be found under Property Window >> Add Control >> Other >> Hook Left Column.
The Shape tab designs the entire hook area - to style the modules in this specific hook, use the Block tab.
The modules can be managed from the PrestaShop back office >> Modules >> Positions. The displayLeftColumn hook shows the modules already added. The new modules can be inserted using the Transplant module option.
###Summary The **Hook Left Column Control** is a [PrestaShop](http://answers.billiondigital.com/categories/3915/prestashop-3) specific control that adds **displayLeftColumn** position, which usually contains the cart module and some modules with products. ###Usage This control adds **displayLeftColumn** position to PrestaShop templates. It can be found under **Property Window** >> **Add Control** >> **Other** >> **Hook Left Column**. !hook-left-themler.png! The **Shape** tab designs the entire hook area - to style the modules in this specific hook, use the **Block** tab. The modules can be managed from the **PrestaShop back office** >> **Modules** >> **Positions**. The **displayLeftColumn** hook shows the modules already added. The new modules can be inserted using the **Transplant module** option. !hook-left.png!
