Drupal has a default RSS feed system which outputs nodes that are "Published" and "Promoted to front page". The default RSS URL is rss.xml (e.g. www.example.com/rss.xml)
The Feed Icons control creates a link to the default RSS feed and uses the native Drupal RSS icon.
The RSS Feed Icon appears on either the Front page, which displays the default content feed, or a blog page ( a page with "node" path).
How to add the RSS feed Icon:
  1. Go to Themler Add Control (Insert) >> Other >> add Feed Icons
  2. Configure the number of items in each feed and feed content under the Drupal Configuration >> Web services >> RSS publishing
### Summary Drupal has a default RSS feed system which outputs nodes that are "Published" and "Promoted to front page". The default RSS URL is rss.xml (e.g. www.example.com/rss.xml) The **Feed Icons** control creates a link to the default RSS feed and uses the native Drupal RSS icon. ### Usage The RSS Feed Icon appears on either the Front page, which displays the default content feed, or a blog page ( a page with "node" path). How to add the RSS feed Icon: 1. Go to Themler **Add Control** (Insert) >> **Other** >> add **Feed Icons** 2. Configure the number of items in each feed and feed content under the Drupal **Configuration** >> **Web services** >> **RSS publishing** !feed-icons.png! !feed-icons2.png!
