The Tabs Menu is a special control used to output the Drupal edit menu which appears for logged-in users who can edit particular nodes.
By default, the Tabs Menu control is added below or above the Drupal content. It can be moved to the any place on the page. It can be added under the Insert >> Navigation >> Tabs Menu.
### Summary The **Tabs Menu** is a special control used to output the Drupal edit menu which appears for logged-in users who can edit particular nodes. ### Usage By default, the **Tabs Menu** control is added below or above the Drupal content. It can be moved to the any place on the page. It can be added under the **Insert** >> **Navigation** >> **Tabs Menu**. !drupal-tabs-menu.png!
