The Hook Right Column Control is a PrestaShop specific control that adds displayRightColumn position.
This control adds displayRightColumn position to PrestaShop templates.
It can be found under Property Window >> Add Control >> Other >> Hook Right Column.
The Shape tab designs the entire hook area - to style the modules in this specific hook use the Block tab.
The modules can be managed from the PrestaShop back office >> Modules >> Positions. The displayRightColumn hook shows the modules already added. The new modules can be inserted using the Transplant module option.
###Summary The **Hook Right Column Control** is a [PrestaShop](http://answers.billiondigital.com/categories/3915/prestashop-3) specific control that adds **displayRightColumn** position. ###Usage This control adds **displayRightColumn** position to PrestaShop templates. It can be found under **Property Window** >> **Add Control** >> **Other** >> **Hook Right Column**. !hook-right-themler.png! The **Shape** tab designs the entire hook area - to style the modules in this specific hook use the **Block** tab. The modules can be managed from the **PrestaShop back office** >> **Modules** >> **Positions**. The **displayRightColumn** hook shows the modules already added. The new modules can be inserted using the **Transplant module** option. !hook-right.png!
