System Requirements
  • Mac OS X 10.10.5 or later.
  • about 1.5Gb free disk space.
  • If you are behind of a proxy server, make sure that you have added 127.0.0.1 to proxy baypass list.
    You can do this from Applications -> System Preferences -> Network -> Advanced -> Proxies.
How To install
  • Download Themler Desktop for Mac
  • Double click on .dmg file
  • Install Themler into Applications directory:
    NOTE: Themler can be installed into Application only.
  • Run Themler:
Directory with CMSs and themes:
Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS
Access to the CMS admin panel
Access CMS admin panel in browser, for example:
http://127.0.0.1:29958/themler_[numbers]/wordpress/wp-admin
Here themler_[numbers] is a dynamic name of the Themler data directory. The exact name can be found in Applications >> Themler (open package) >> Contents >> Resources >> hd_data >> themler_[numbers]. For example; themler_2092279974
Login/Password:
admin/admin
## System Requirements - Mac OS X 10.10.5 or later. - about 1.5Gb free disk space. - If you are behind of a **proxy server**, make sure that you have added `127.0.0.1` to proxy baypass list. You can do this from Applications -> System Preferences -> Network -> Advanced -> Proxies. ## How To install - Download Themler Desktop for Mac - Double click on .dmg file - Install Themler into Applications directory: !mac-install1.png! **NOTE:** Themler can be installed into **Application** only. - Run Themler: !mac-install2.png! ## Directory with CMSs and themes: Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS ## Access to the CMS admin panel Access CMS admin panel in browser, for example: `http://127.0.0.1:29958/themler_[numbers]/wordpress/wp-admin` Here `themler_[numbers]` is a dynamic name of the Themler data directory. The exact name can be found in Applications >> Themler (open package) >> Contents >> Resources >> hd_data >> themler_[numbers]. For example; `themler_2092279974` Login/Password: admin/admin
