Normally the Horizontal Menu is a main website navigation section which is intended to assist visitors in navigating through the website pages.
  1. Add the Horizontal Menu control to any place on the page where you want the Menu to appear.
  2. Apply changes to the CMS.
  3. Go to Drupal Admin Panel >> Configuration >> Development >> Performance and clear caches so that the new region is visible.
  4. Go to Drupal Admin Panel >> Structure >> Menus and create a regular Drupal menu. If you already have a menu you can skip this step.
  5. Go to Drupal Admin Panel >> Structure >> Blocks.
  6. Find the Menu block and change its region, e.g. "Horizontal Menu 1"
NOTE: You can create an unlimited number of Horizontal menus. Each new Horizontal Menu control will create sequential regions, e.g. "Horizontal Menu 2".
Important: Please make sure you have placed blocks in regions in the same way both for Preview theme and Basic theme - this can be set by clicking "Configure" next to the region selected:
### Summary Normally the **Horizontal Menu** is a main website navigation section which is intended to assist visitors in navigating through the website pages. ### Usage 1. Add the [Horizontal Menu](page:4756) control to any place on the page where you want the Menu to appear. 2. Apply changes to the CMS. 3. Go to **Drupal** Admin Panel >> **Configuration** >> **Development** >> **Performance** and **clear caches** so that the new region is visible. 3. Go to **Drupal** Admin Panel >> **Structure** >> **Menus** and create a regular Drupal menu. If you already have a menu you can skip this step. 4. Go to **Drupal** Admin Panel >> **Structure** >> **Blocks**. 5. Find the Menu block and change its region, e.g. "Horizontal Menu 1" **NOTE:** You can create an unlimited number of Horizontal menus. Each new Horizontal Menu control will create sequential regions, e.g. "Horizontal Menu 2". !drupal-hmenu.png! **Important**: Please make sure you have placed blocks in regions in the same way both for [Preview theme and Basic theme](page:3727) - this can be set by clicking "Configure" next to the region selected: !drupal-region-settings.png!
