  • Reduced the time for switching between templates, Save, Download, Live preview, and Control inserting operations
  • Different Performance Issues
  • Numerous Crashes
  • Numerous Memory Leaks
  • Improving the data sending mechanism to the CMS server should reduce the Save time
  • Prestashop, Drupal: Unused images will be removed after theme saving so theme size will be significantly reduced
  • Joomla: several Horizontal Menu Controls can be added
  • Fixed IE Search Control issue
  • Hover item border fixed when border is used as separator between Menu items
  • Fixed "left" Positioning for the Old price in Product price
  • Fixed issue with control highlight in Preview when hovered in Path and Outline
  • Selection frame now ignores the Bootstrap negative margin for Row and Container and is shown as close as possible to the Control
  • Vertical-align option was added for every Control in Custom tab
  • Fixed issue with Control adding to the Header with Padding
  • Selection frame when clicked in Submenu doesn't break the display of Justified Menu anymore
  • Added Full Page Width option
One Page Design
Overview
One Page design is a modern design trend, long-scrolling webpages are appealing and easy to navigate.
How to create One Page Dsign
One Page Design In WordPress
Themes:
- Default WordPress One Page Design Theme
- SymPlex
One Page Design In Joomla
Templates:
- Default One Page Design Joomla Template
- BiziCo
New Templates
WooCommerce
VirtueMart
Activity per day
We work really hard to make the best product possible.
You can see the number of opened and closed cases per day.
Cases Trend
You can see that last month the number of bugs and crashes was significantly decreased:
Previous updates
### General - Reduced the time for switching between templates, Save, Download, Live preview, and Control inserting operations - Different Performance Issues - Numerous Crashes - Numerous Memory Leaks - Improving the data sending mechanism to the CMS server should reduce the Save time - Prestashop, Drupal: Unused images will be removed after theme saving so theme size will be significantly reduced ### Controls - Joomla: several **Horizontal Menu** Controls can be added - Fixed IE Search Control issue - Hover item border fixed when border is used as separator between Menu items - Fixed "left" Positioning for the Old price in Product price ### UI - Fixed issue with control highlight in Preview when hovered in Path and Outline - Selection frame now ignores the Bootstrap negative margin for Row and Container and is shown as close as possible to the Control - Vertical-align option was added for every Control in Custom tab - Fixed issue with Control adding to the Header with Padding - Selection frame when clicked in Submenu doesn't break the display of Justified Menu anymore - Added Full Page Width option !full-background.png! ### One Page Design #### Overview One Page design is a modern design trend, long-scrolling webpages are appealing and easy to navigate. [How to create One Page Dsign](page:4782) #### WordPress [One Page Design In WordPress](page:5581) Themes: - [Default WordPress One Page Design Theme](http://templates.themler.com/Themes/Detail/1889061) - [SymPlex](http://templates.themler.com/Themes/Detail/1889303) #### Joomla [One Page Design In Joomla](page:5582) Templates: - [Default One Page Design Joomla Template](http://templates.themler.com/Themes/Detail/1888797) - [BiziCo](http://templates.themler.com/Themes/Detail/1889546) ### New Templates #### WordPress <a href="http://templates.themler.com/Themes/Detail/1889303"> <img src="http://thumbnails.billiondigital.com/116/894/1894116/2171548_small.jpg"/> </a> #### WooCommerce <a href="http://templates.themler.com/Themes/Detail/1894193"> <img src="http://thumbnails.billiondigital.com/493/895/1895493/2175866_small.jpg"/> </a> #### Joomla <a href="http://templates.themler.com/Themes/Detail/1894196"> <img src="http://thumbnails.billiondigital.com/609/894/1894609/2173173_small.jpg"/> </a> <a href="http://templates.themler.com/Themes/Detail/1894522/Vacation"> <img src="http://thumbnails.billiondigital.com/206/895/1895206/2175028_small.jpg"/> </a> #### VirtueMart <a href="http://templates.themler.com/Themes/Detail/1894400"> <img src="http://thumbnails.billiondigital.com/566/894/1894566/2173027_small.jpg"/> </a> <a href="http://templates.themler.com/Themes/Detail/1894195"> <img src="http://thumbnails.billiondigital.com/334/894/1894334/2172253_small.jpg"/> </a> ### Activity per day We work really hard to make the best product possible. You can see the number of opened and closed cases per day. !cases-days.png! ### Cases Trend You can see that last month the number of bugs and crashes was significantly decreased: !cases-number.png! ### See Also <a href="http://answers.billiondigital.com/categories/3916/">Previous updates</a>
