In Magento, the Products Slider can be added anywhere on the page.
  1. Add the Products Slider control to any place on the page where you want the slider to appear. You will see the message prompting you to configure the Slider in the Magento Admin Panel - this message contains the slider name.
  2. Apply Changes to CMS.
  3. Go to the Magento Admin Panel >> BillionThemes >> click Settings:
4. Switch to Sliders tab >>, find the Slider and select its Source:
### Summary In Magento, the **Products Slider** can be added anywhere on the page. ### Usage 1. Add the [Products Slider](page:4780) control to any place on the page where you want the slider to appear. You will see the message prompting you to configure the Slider in the Magento Admin Panel - this message contains the slider name. 2. Apply Changes to CMS. 3. Go to the Magento **Admin Panel** >> **BillionThemes** >> click **Settings**: !theme-settings.png! 4. Switch to **Sliders tab** >>, find the Slider and select its Source: !magento-theme-settings.png!
