Overview
Default Styles allow you to define styles common for most basic controls in one place.
These styles are applied to controls that do not have customized styles.
Default Styles can be found at Styles > Default Styles.
Custom Control Styles
Once a control supporting Default Styles is edited, you can see the following:
Click Reset to Default if you want to use styles from Default Styles page.
Click Set as Default if you want to replace styles from Default Styles page with the current control's style.
The example below shows two Button controls. The first Button is customized, the second one uses the default style.
Sheet and Page Background
Page Background and Sheet have Default Styles, but they are not present on the Default Styles page. Sheet and Page Background Default Styles may be set while editing them in the Property Window.
While editing Default Styles you can see the following:
If you want to customize style, click Customize Template Styles
The example below shows four Templates: the first three use Default Styles, the fourth one is customized.
### Overview
Default Styles can be found at **Styles** > **Default Styles**.
!default-styles.png!
### Custom Control Styles
!reset-to-default.png!
Click **Reset to Default** if you want to use styles from **Default Styles** page.
Click **Set as Default** if you want to replace styles from **Default Styles** page with the current control's style.
The example below shows two **Button** controls. The first Button is customized, the second one uses the default style.
!default-styles-examples2.png!
<a id="sheet-and-background"></a>
### Sheet and Page Background
Page Background and Sheet have Default Styles, but they are not present on the **Default Styles** page. Sheet and Page Background Default Styles may be set while editing them in the Property Window.
!customize-template-styles.png!
If you want to customize style, click **Customize Template Styles**
!default-styles-example.png!
