The Vertical menu is usually used as a secondary website navigation tool; it is created by using the Vertical Menu control.
To add a Vertical Menu to your website please follow the next steps:
1. Log-in to your Joomla admin panel
2. Create a standard Menu under the joomla >> Menus
3. Create a Menu Module under the Module Manager
4. Specify " vmenu" Module Class Suffix (with a leading space) under the Advanced Options of the chosen Menu Module:
### Summary The Vertical menu is usually used as a secondary website navigation tool; it is created by using the [Vertical Menu control](page:5109). ### Usage To add a Vertical Menu to your website please follow the next steps: 1. Log-in to your Joomla admin panel 2. Create a standard Menu under the **joomla** >> **Menus** 3. Create a **Menu Module** under the **Module Manager** 4. Specify " *vmenu*" **Module Class Suffix** (with a leading space) under the **Advanced Options** of the chosen Menu Module: !vmenu--1-.png!
