To add translatable static text, for example, a static text inside Themler Slider, please try the following solution:
  1. add CMS Code control available under the Insert tab >> More to the desired place on the page. In this control add the text that you want to translate in the following way:
    {l s='Testing'}
    Here Testing is the translatable text.
  2. Go to the PS admin panel and translate under the Localization >> Translations >> choose template and Language and search for translation key.
The appearance of the CMS code content can be configured on the ribbon:
To add translatable static text, for example, a static text inside Themler Slider, please try the following solution: 1. add **CMS Code** control available under the Insert tab >> More to the desired place on the page. In this control add the text that you want to translate in the following way: `{l s='Testing'}` Here *Testing* is the translatable text. 2. Go to the PS admin panel and translate under the Localization >> Translations >> choose template and Language and search for translation key. The appearance of the CMS code content can be configured on the ribbon: !cms-code-settings.png!
